Results 1 to 5 of 5
Thread: Tailshaft - non replaceable parts?
    VZ SV6
    Jul 2009
    Default Tailshaft - non replaceable parts?
    I have a vibration that I suspect is a problem with the tailshaft. Took the car in for a full service, new tyres, the lot, and asked them to check the vibration. They found that 2 of the 4 centre bearing bolts were gone from one side so they replaced them. They said that they couldn't see anything else wrong with it but if the vibration is still there (which it is although not as bad as it was), then I'd have to take it to a driveline specialist. Rang around a couple of places (not Holden service centres) and have been told that Holden made the VZ SV6 with non-replaceable centre bearing & universal joints so if there's a problem, replacing the tailshaft is the only alternative. Anyone know if this is definitely correct?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    i think thats half true, i think you can buy a new front half or a new rear half,
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    2003 CV8R Monaro
    Mar 2008
    Liverpool
    I had a similar problem. My Monaro gets a fair beating, so suffice to say, it's only a matter of time until something claps out. Usually it's just tyres, but I did go through 2 standard clutches in about 1 1/2 years. A Textralia Z-Grip soon fixed that, so armed my with my awesome new clutch, 5000rpm launches became the norm.
    This time, it was the centre bearing in the tailshaft. I rang McGrath's and was told that the centre bearing is a non-servicable item and a complete tailshaft is all they sell, which retails at close to $1000. After almost collapsing at the price, I rang around a bit for a second hand unit, it'll get me going again for the meantime. I am in the process of researching the possibility of having a custom one piece tailshaft made up. They put the 2 piece tailshaft in to supposedly reduce driveline vibrations.
    Towards the diff there is a white sticker on the tailshaft, it will be either NA or NE, then ring your favourite Commodore wreckers and tell them that that is the tailshaft that you need. I rang Commwreck in Condell Park, they wanted $330 inc. GST and Smithfield Auto Wreckers want $250 inc. GST. Then grab a slab of your choice, enlist the help of some eager mates, then sit back sinking coldies as you watch them swapping your dud tailshaft over for your new one. Too easy.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ok heres the go for the v6's
    5sp auto and 6sp manual have a splitable tailshaft that you can seperate and press off the centre bearing and re-fit a new one,
    4sp auto is fitted with a pressed together tailshaft with a non servicable uni joint that dosnt allow splitting the shaft, so a new or reco tailshaft from a driveline mob is needed
  1. passengers airbag cover warped, replaceable ?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 08:42 AM
  2. VP replaceable sensors? which ones?
    By discostuee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2008, 11:49 AM
  3. VS V6 Tailshaft $10(and more vs parts cheap)
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 15-10-2008, 09:00 PM
  4. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  5. v8 conversion parts - motor box ecu loom kframe tailshaft lsd
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 16-04-2007, 10:13 AM
Tags for this Thread
