Results 1 to 4 of 4
Thread: Indicator stays on
    VZ Exec
    Aug 2009
    WA
    Question Indicator stays on
    Hi. I saw a thread earlier about someone having the same problem with their VZ ute in that when you lock the doors, the right indicator stays on. Advice given to the guys simply suggested he take his ute back under warranty and get it fixed. Mine's out of warranty and I'd just like to know if anyone has any ideas on what could be the problem. i'm thinking of changing the flasher unit to start with.
    Any ideas please?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by Jono61 View Post
    Any ideas please?
    It will be the Body Control Module (BCM), a common VZ fault. New ones cost around $500 trade with new key heads coded to match, but Doctor Bob on this forum can repair them for considerably less. You will be wasting your time trying to fix the problem by changing the flasher unit.
    The BCM is located under the right hand dash panel, immediately above the accelerator pedal. It is retained by two clips on top and one scrivet on the bottom RH corner.. To gain access, remove the lower RH dash cover panel that sits immediately above the pedals. You will see the BCM, a grey plastic box with three sets of wires leading into it. Reach up and unclip the two top clips and cut the scrivet out using a sharp chisel - it is difficult to remove any other way because of its location. (Don't bother replacing it). Drop the BCM, disconnect the wiring and you're on your way. Replacement is simply connecting the wiring and pushing the BCM back into place for the two clips to engage.
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Or if you want a dodgey solution, put a relay in that closes when the ignition is on...
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    VZ Exec
    Aug 2009
    WA
    Default Indicator stays on
    Thanks heaps! I'll check it out.
  1. Right Indicator Stays On
    By mailyesac in forum Electrical Wiring / Questions
    Last Post: 28-07-2011, 05:55 AM
  2. Air Bag Light Stays On
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2009, 03:53 PM
  3. Air Bag light stays on
    By jimmyd17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2006, 07:12 PM
  4. Aerial stays up in VT...
    By zooyorker in forum Car Audio
    Last Post: 24-01-2005, 03:51 PM
  5. Thermo Fan Stays On
    By nickcronin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2004, 02:03 PM
