Results 1 to 10 of 10
Thread: ECU in a VZ
    VZ Acclaim
    Aug 2009
    Default ECU in a VZ
    Where abouts is the plug for the ecu system in an alloytec 175 ?
    VZ SV6 && 180sx
    Mar 2008
    VZ Acclaim
    Aug 2009
    Thanks, So if you were to disconnect it, would you disconnect it there, or at the ecu box?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    on a vz its called a ecm,
    the ecm is bolted to the front of the motor as said, you will see 2 plugs, the top plug that runs up near the fuse box is the one you disconnect the motor from the cars wiring, the bottom plug, runs the motor loom, so all the sensors connect to that
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Acclaim
    Aug 2009
    so if you disconnect the one that goes to the fuse box, will the engine still start and run?
    I've heard if you disconnect it, the engine doesn't have the limitations, like the anti abuse shit.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by VZknights View Post
    hahahaha, sorry but that made my day,
    no the car wont start,
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    VZ Acclaim
    Aug 2009
    you know what makes my day, andyman thinks he's a hero.. when he only knows that because he tried it himself
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    oh yeah, of course i disconnected the the wiring harness to motor, i just wanted to see how limited the car was after
    Exidor's Avatar
    May 2008
    Earth. For now....
    Talking
    Oh man, keep it up!
    I'm not afraid.
Tags for this Thread
