Results 1 to 10 of 10
Thread: disable main immboboliser
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    Default disable main immboboliser
    hey, today i just got installed a 2 way pager alarm with remote start in my commodore vz, however, i think the stock imoboboliser is screwing arouind with it, as when i press unlock on the holden key, only then will it allow me to remote start. if i dont press it, the dash lights turn on, but the starter wont ignite. does anyone know how i can override the stock holden alarm/imboboliser?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you'll be lucky if you can id imagine
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jun 2009
    Castle Hill, Sydney
    are you serious? i remember on my toyota i just had to leave the key in the ignition on the ON position for 1 hour and it disabled it. doesnt commodores hve something like that?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    never heard of doing anything like that,
    vz;s use a vats link system, you can remove that in a tune, but i doubt itll remove the imobiliser
    VZ SV6
    Aug 2008
    mate the vehicle imobiliser is in-built to the computer etc. have fun...... coz thats like opening a pandora's box if you dont know what you looking at.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    The purpose of the imobiliser is that it can't be tampered with or disabled.
    Jun 2009
    Castle Hill, Sydney
    Is there anyone else out there who has the same problem? Anyone whose installed a two way pager alarm with remote start?
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Never dabbled with remote starter........ but I'm guessing you'll need VCM Suite to disable "parts" of the ECU's immobiliser protection gear.
    eg. Starter Relay stuff, Ignition Incorrect Key, Ignition Blank Key stuff.
    Anything that registers a Drivability Fault (non-emmisions) will immobilse the car which is probably whats happening to you. It's a matter of trial and error thru the Engine Diag > DTC's area.
    You shouldn't have to disable the immobiliser to make this work, just adjust some of the things that set it off.
    PS. You'll probably void insurance if they ever found out tho....... as they have a 3 point system, and turning off say the key checking makes it a 2 point. If it's just the starter relay causing the issue then that'd be fine to be disabled.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    mate i had the exact same problem in my commo. I kept getting mixed answers, in the end i believe it was possible to do, but as i sold the car i never had it done.
    Jun 2009
    Castle Hill, Sydney
    yeh i havent had much luck so far, ive looked everywhere i can. i have a mate who had some guy disable his bmw immobolizer, so im gonna try n give him a shot next week n see if he can do it to a holden. would it void insurance even though ive upgraded to a more powerful alarm?
  1. Disable a spark plug
    By VZCalZone in forum Electrical Wiring / Questions
    Last Post: 25-05-2009, 05:19 PM
  2. disable alarm
    By smile in forum General Discussion
    Last Post: 13-04-2009, 11:47 PM
  3. Disable Alarm
    By omar302 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-03-2007, 09:50 PM
  4. How do I disable an imobilizer?
    By V8commodore_chick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2006, 05:47 PM
  5. Correct way to disable SRS system
    By Thumpin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2005, 04:19 PM
