Results 1 to 18 of 18
Thread: SRS Airbag Fault + SVS Alarm
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default SRS Airbag Fault + SVS Alarm
    Yesterday i pulled the seats outta my SV6 to get in and give it a clean, forgetting to undo the battery i disconnected the yellow and orange wires. After reisntalling the seats/connections i started the car for it to beep at me saying 'SRS Airbag Fault' as i expected this to happen anyway. I have 'reset' the ecu by removing the negative cable of the battery and this hasnt cleared the 'fault'..
    I also keep getting beeped "Service Vehicle Soon" when sitting at traffic lights and starting the car. After reading i have gathered it could be the oil pressure sender, is there any one who has corrected this problem without replacing parts?
    any help would be great thanks..
    Life starts at 200km/h
    chrism182's Avatar
    chrism182 is offline VX S Pack
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    You'll need to take it to a Holden dealer and get them to reset the code with a tech2.
    eziautoparts.com.au
    Your total auto parts store on the web!
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    does anyone in the forums have tech 2 and can they clear these faults for me? Im in Brisbane
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    most good workshop will have a scan tool that can remove the code, walk in there with a 6 pack and ask if they can do it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    yeah thats my other option, ohwell another day with my car carrying on like a lunatic.. lol stereo must go up
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    Quote Originally Posted by impulsive View Post
    i suppose i could always disconnect the speedo haha
    How would that help?
    I've had the SVS warning for the past month or so... just gonna take it to someone with a scan tool when I have the time and ecpecting to have to replace the oil pressure sender. From previous posts on here that seems to be the most common fault. I don't think clearing a fault code will fix anything, especically considering it only comes up when first starting the car or when stopped and idling for a little while. If I keep my rev's up above 1k when stopped the SVS warning doesn't come up... pretty sure it's a genuine fault. Not just a simple ECU reset fix.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by JBDrifter View Post
    maybe you should keep your daft comments to yourself.. As far as i was aware tech2 indicates faults aswell, so in clearing the Airbag fault i will get it checked for the service vehicle fault..
    And if it is a genuine fault as you so clearly put it why havent you got it fixed.. cant be anything too serious..
    mate this is a car forum not a forum for know it all's.. unless you have a genuine post or suggestion dont bother with my threads..
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    from what i gathered from the mechanic from roadside assisstance it is not an oil pressure sender as the car would be throwing fault codes up at me..
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Caution.
    Some information given to me by a Holden technician.
    If you vehicle is displaying an SRS fault it also means
    should you have an accident your air bags will not deploy.
    I'm not afraid.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by rodbol View Post
    Caution.
    "may" not deploy, i know the reason the fault has occured and it is as simple as clearing the log.. UNLESS tech2 shows other faults.. althought i wont be driving too much till i get to a dealer
    thanks anywayz, would hate to die because the airbags didnt go off..
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    on diagnostics side, its no different to decent scan tool these days, they only give you the fault code basically, the you have real time sensor output displays etc,
    its the programming side of this that makes it different
    JBDrifter's Avatar
    Oct 2006
    Mate do a search on SVS fault and see what you find. I was simply trying to be helpful. Yes, when you have you car scanned to clear the airbag fault they will also find the exact fault causing the SVS warning. From my research I have found that the most common cause is the oil pressure sender.
    Maybe your mechanic is not familiar with VZ's... faulty oil pressure sender does throw out a fault code, which you will only find with a Tech2 or other compatible scan tool. It also causes the SVS warning, among other faults, but like I said the oil pressure sensor is the most common.
    I think it is a genuine fault because it only comes up when you first start the car or when car is at idle for a short period. All other times, the warning goes away. This would also fit with an oil pressure fault.
    But what do I know hey? Go get it scanned and tell us the verdict.
  15. #15
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    sorry mate thought you were having a go at me, everyone seems to have a go here.. thanls for ya help.. im going to holden tomorrow to get it checked out but i will let you guys know
  16. #16
    VZ commodore SV6
    Sep 2010
    Hi mate
    My VZ V6 SRS Module is faulty
    Do you know that where is installed. i had a look under the glovebox and behind the fuses i couldnt find it.
    So if you know where about it stays.Could you plz let me know.
    Thanks
    Gary
  17. #17
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Garywrx View Post
    Hi mate
    Thanks
    Gary
    The SRS Sensing and Diagnostic Module (SDM) is mounted on the floor pan, and is located under the centre console directly beneath the large centre console storage compartment.
  18. #18
    VZ commodore SV6
    Sep 2010
    Thanks mate.
    I found it.thanks
    cheers!!!!!
  1. SRS Airbag Fault
    By The Windsurfing VY Wagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-08-2011, 01:03 PM
  2. SRS Airbag fault
    By sajesh in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-04-2010, 02:08 PM
  3. SRS Airbag Fault
    By adamc11 in forum General
    Last Post: 30-08-2009, 02:45 PM
  4. srs airbag fault
    By slothysid in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-04-2009, 08:43 PM
  5. HELP - SRS Airbag Fault
    By MyPetFly in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-11-2007, 12:14 PM
