Results 1 to 6 of 6
Thread: installing pod filter
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    Default installing pod filter
    i took my stock air box off but i left the sensor wire on on the hose. then i connected a pod filter at the end, however, the car stalls n suffers n turns off eventually in idle, but then when i put the stock airbox back on, it works perfectly. WHAT???? all im saying is, the engine is smart enough that it knows whats going on?
    did anyone else have this problem? if so, whatd you do?
    FG XR6T Ute manual
    May 2007
    Brissy
    Pod filters are pretty crappy. You would be better off doing the 2 hole mod. Do a search and plenty of info should come up
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    Jun 2009
    Castle Hill, Sydney
    VZ SV6 && 180sx
    Mar 2008
    MACE do a good CAI, basically a pod in a box, which has be found to improved performance..
    $270 for their kit.
    commodore
    Aug 2009
    australia
    pods are crap your better off with a k+n or simailar flat panel filter in your stock airbox and a cold air intake going to your airbox youll get more power than just a pod sucking in hot air
    Jun 2009
    Castle Hill, Sydney
    oh nice. ill look into it
  1. installing pod filter in VR
    By clazzza commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2009, 11:13 AM
  2. worth upgrading air filter if im installing COI?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 08:06 PM
  3. pollen filter/air con filter
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-05-2009, 11:45 PM
  4. installing a pod filter on a stock vk calais
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2006, 03:36 PM
  5. Installing pod filter...
    By baz_ka40 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2005, 06:44 PM
