Results 1 to 14 of 14
Thread: VZ doesn't start
    VZ Ute
    Aug 2009
    Default VZ doesn't start
    I've had this car about 4 months and this has happened three times, most recently today.
    I'll have gone somewhere and the car would have been parked for 30 minutes of so. Turning the key on and car doesn't start. Nothing. Try a few times, watch the System check, says OK, but might say fuel very low despite having a full tank. Fuel gauge needle shows empty. This time, it also said fuel gauge error and also service due notice (ODO is 41,000 and next service is 45,000)
    So far, touch wood, if I wait about 10 minutes and try again, it starts ok.
    Is this a common problem. Is it a fixabe fault? I'm spooked now and have just gone out and purchased roadside membership in case the next time, waiting 10 minutes doesn't fix the problem.
    It seems to me like a computer problem.
    May thanks in advance for any suggestons.
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    er i would just take it to a mechanic and get it checked out, ive never heard of such an issue
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Could be your battery on the way out. Have it 'load tested' by an auto electrician.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    there have been a few complaints about this.. i feel it might have something to do with the fuel pick up in the tank.. try resetting your ECU and physically checking the fuel level, this only happened to me on an empty tank. The car thinks there is no fuel in the system so it automatically shuts the computer down to prevent fuel lines getting air, i think its like the car recoginises an issue and shuts down to prevent further damage or complications.
    Just make sure you check the fuel level by tapping the tank, or dipping with a clean coathanger or similiar object
    Life starts at 200km/h
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Benboy View Post
    most batterys that are out these days have a little window that displays a colour, Green for fine, Black for recharge, or Red for dead..
    if yours doesnt have this and you arent to sure about your batterys condition, check that its clean and the terminals are tight and not corroded.. if its open cell as in if you can check the electrolyte level obviously make sure they are above the fins inside.. if not they say spring water (i think) can be used or buy some electrolyte from autobarn..
    Although there shouldnt be any problems between the battery and fuel error best to check this occasionally anyway!
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    We had a long thread about this not long ago, figured we had it sorted.......... being that it was the Starter Relay playing up, causing the ecu to immobilise the car as it was a drivetrain non emissions fault........ when it immobilises it cuts fuel, starter and ignition basically hence the fuel guage fault.
    Evidentally, we disabled that in the ecu.......... we thought it was fixed, now 3 months later our project VZ we're working on is doing it again. I would suspect atm.........
    1. Pull the tank off the car, replace EVERYTHING.... sender, float, clean it....
    2. Track back the wiring from the fuel sender all the way back to where ever it goes. Make sure the wires are in good nic, no fray, earthing etc....
    3. Take it to eagers ask them and get the computer updated.
    4. I've heard stories it could even be your key going flat......... in theory you put it in, it's blank (no code, old wrong code)........ the immobiliser picks it up and immobilises the car.
    Good luck bud.
    PS. I suppose in reality it could simply be a bad batch of immobilisers, the only thing none of us have all ever considered. So many people have tried so many things ....... Ours does it now virtually within 30 mins. My next step will be to completely remove anything that could stop it from starting in the computer, then unlike the immobiliser......... new key, and very last the list above.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ Ute
    Aug 2009
    Thanks for the suggestions. Hopefully I don't need to go through what bigdaddycool has to resolve.
    I doubt the key battery is the cause in my case as it is only 2 months old.
    Will post the solution to my problem if/when resolved.
    doms3 is offline Banned
    Vz
    Sep 2007
    Quote Originally Posted by intoodeep View Post
    We had a key newly cut fail on us within 2 days so you never know ,
    VZ Ute
    Aug 2009
    I''m starting to feel confident that the problem has been resolved. I had it checked out a couple of months ago and while nothing was found, they did redo the connections (to the fuel sensor I think) and the problem hasn't returned. Fingers crossed.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    its a break in the can system, id suspect powertrain interface module, if the pim dosnt respond all the modules in the car will not communicate as vz's use the can protocol, although recently i delt with one, but that ended up being the ecm
    if you say disconnect the transmission control module, and the can wires (high and low speed) are open circuit, it replicates that fault to a T
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    also if the car locks out like that, it will start by shorting out pins 30 and 87 in the starter relay with the ignition turned on
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    also to add, generally if its the imobiliser, it will only show service vehicle soon, as it will log theft deterent signal missing
    VZ Ute
    Aug 2009
    Well, after 15 months troublefree, it happened again :-(. Same scenario - car parked for 20-30 minutes after being warm, turn key, fuel gauge stays on emtpy, no sound from fuel pump.
    I took it to Motors and this time they checked the Powertraim Control Module and found it to be faulty. Estimated $900 fitted and programmed (ouch) I'm crossing my fingers that it fixes the problem. From andyman's contributions (thanks), it seems like it might be a fix.
    VE Omega sedan 3.0 2010
    Feb 2011
    Fly Creek, N.T.
    intoodeep: I'm interested to hear how your VZ is progressing ...
  1. Start in N
    By Wilson_752 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2007, 02:04 PM
  2. Didn't Want To Start
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 03:14 PM
  3. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  4. VS Won't Start!
    By ramz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2005, 01:50 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
