Results 1 to 6 of 6
Thread: VZ Auto Changeover
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool VZ Auto Changeover
    G'day Guys
    Anyone change out the 4L60 four-speed automatic on the alloytec
    for the 5L40 five-speed automatic
    as I'm planning a diff upgrade I thought the 5L40 might be a better option
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Diff upgrade would be easier. If you change the auto (if you actually can without issue) ......... in theory your engine tune would have to be changed to suit............ as your optimal torque, open throttle ve tables ......... basically everythings set to work around 4 gears..... so the sv6's for example with 5 speed gearboxes are tuned much differently then the 4 speeds.
    Diff quickest solution on this one.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    changing the diff will then throw out the tune and gbox as well thinking its doin a speed when its not. if youve got the money go both with a tune or just the 5 spd with tune, my 2c
    Matt
    Sep 2008
    tis true, diff will throw out the gearbox............. but it's all of 1 setting to change that in the ecu.......... wouldn't cost much to have eagers adjust it. the guys who do diffs might even be able to
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    4sp auto to 6sp manual is possible,
    4sp to 5sp auto is possible if you are prepared to remove the entire dash board to replace the main dash harness,
    differance is in the wiring at the plug, the 5sp uses security lock connectors and extra wiring, 4sp dosnt,
    just stick some 3.7's if you do fair bit of freeway driving, use 3.9's if you dont,
    get a vcm tune to suite, you wont be dissapoiinted
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    drop in a manual 6 speed and be done with the parts bin, gearboxes
    Life starts at 200km/h
  1. gearbox changeover
    By TRYMY6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2010, 10:25 PM
  2. VP to VR changeover
    By discostuee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2009, 09:30 AM
  3. front bar changeover
    By Ripcell in forum General
    Last Post: 05-03-2008, 06:40 PM
  4. dash changeover
    By PSIHTR in forum General Discussion
    Last Post: 07-05-2007, 10:42 PM
  5. Vk Calais Efi 202 changeover
    By sandman_538 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-07-2005, 06:18 PM
