Results 1 to 7 of 7
Thread: vz shit radio reception
    vz svz ute
    Jun 2009
    Question vz shit radio reception
    just wondring i bought a new headunit and wondering what i should connect the ground wire to so i can get the best reception ?? coz its pissin me off lol ,
    also the remote wire for the rca's connects to a white and blue wire its an aftermarket plug ?? dose this sound right ?
    thanks alot
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    reception will mainly depend on your antenna, the only difference the grounding location will make is engine and alternator interference and buzzing noises through your speakers. with a new head deck, i suggest grounding to a new location on your chassis and make the wiring as short as possible. you could consider a fm radio expander as well if the problem doesnt go away
    kingtutty1 is offline purpzvk
    Vk berlina
    Oct 2009
    bendigo
    the remote wire is normaly for an amp so it shouldnt be wired to anything eles
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by simoo View Post
    thanks alot
    So what you are actually saying is that you bought a new head unit and it's p.....g you off. NOT that the VZ radio is actually the problem. Why not make it clear and say it as it is when you post. To do otherwise makes you sound as if you are just ignorant.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    if u got a amp in the boot, if u got the power cables and rca's down the same side of the car that'll effect everything sound wise........... if it's just the radio for the headunit......... as long as u got the converter plug etc.......... then it should be ok. it is a little crappy, suggestions would be to sheild everything........
    Heatshrink, electrical table the radio plug etc......... also (since I've changed my headunit 3 times) some head units are just crap.........
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    06 VZ SV6
    Mar 2008
    Yeh, you have to get a euro adapter for the antenna. Ive heard a few people having problems with the vz's and reception, myself included, i havent tested how to fix it coz i hardly listen to radion. What bigdaddycool has suggested would be a good starting point
    Daz
    PHOEN1X - 06 VZ SV6
  1. Vz radio shit reception ! Help!!
    By simoo in forum Car Audio
    Last Post: 21-08-2009, 04:59 PM
  2. FM Radio Reception
    By Wokka in forum Car Audio
    Last Post: 25-08-2006, 12:16 PM
  3. radio reception??
    By quiksilver1 in forum Car Audio
    Last Post: 04-06-2006, 01:21 PM
  4. crappy radio reception
    By jams351 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-12-2005, 09:46 PM
  5. '00 Barina radio reception
    By kaycee in forum Car Audio
    Last Post: 02-12-2005, 01:59 AM
