Results 1 to 8 of 8
Thread: HELP! SRS Fault with new headunit!!!
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Default HELP! SRS Fault with new headunit!!!
    SRS fault is fixed
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Did you remove the driver's airbag to
    check the s/wheel button wiring.
    Then turn ignition on without airbag
    connected?
    This will give an SRS fault which will
    need to be reset via OBD2 port.
    Can't help with the audio controls.
    I'm not afraid.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    No i didnt remove the airbag at all! How do i clear the fault? like can i do this personally? Whats the OBD2 port? anyone else have any ideas on this problem please!
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Ok i think i worked out one of my problems! When i put the new head unit in, there were two codes written down... I am guessing i entered the wrong code and the head unit only half activated! Is there a way to clear the code off the head unit so as to enter in the other???? Please help!
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Maybe if you disconect the battery it will wipe out the old code then you can enter the new one
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    I tried diconnecting the battery and removing the head unit and also resetting the pcm???
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by Burto89 View Post
    sounds like something else has gone astray
    simply changing the radio will not inerfere with the srs in any way
    you need to get a scantool onto it to see what is wrong.
    sounds like the clockspring has a fault.
    Rob
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Ok guys dont worry bout the SRS thing i am getting it reset at Holden tomorrow! What i really need is help sorting out the steering wheel controls for my stock head unit! Please help!
  1. new headunit ~$200?
    By Razor- in forum Car Audio
    Last Post: 15-08-2009, 10:38 PM
  2. help please with headunit
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 09:41 PM
  3. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  4. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
