Ok so i put a different head unit in my ute and used the wrong code. It activated but now the steering wheel controls are not working. So i am thinking its because the code was wrong!
How do i go about resetting the head unit so as to enter in the correct code?
disconnecting the battery should allow you to re enter the pin.
I highly doubt that entering the wrong code would activate the head unit without steering wheel functionality.
Wrong code = no activation.
Take it out again and double check the wiring.
Ok i will give it a go!
So you put a different Blaupunkt unit in right??
Yea Kal put a head unit out of my vy in. The one in the vz was scratched to buggery. any ideas?
Nah it should work fine..
Maybe take it to holden to get it programmed to your VIN.. Should cost $25
Try and put your old one back in aswell, and see if Steering Controls work with that one...?
Hey Kal, i tried putting the old one in and it also doesnt work??? starting to think the controls have died perhaps?
just FYI the BCM? remembers the PIN for the radio from factory.
When you put a new heard unit in and enter the PIN the BCM remembers that. You can remove the radio in and out and wont be asked for the PIN, until you go and put a different head unit in.
Unplugging the battery etc doesnt really matter, the head unit resets after 15 mins whether its connected or not. just have to wait it out if you've locked it.
argh, something like that![]()
