Results 1 to 17 of 17
Thread: abs fault?
    Escape-The-Fate's Avatar
    Escape-The-Fate is offline HSV, i just want one
    VE SS, M6
    Nov 2008
    Gold Coast
    Default abs fault?
    ok well just finished work after a long day and was walking out to the carpark..admiring my car shining in the afternoon sun thinking wow thats sexy haha..and i jump in take the window visor down and start it up and as i shut my door the car beeps at me..what the hell..
    look down at the screen and its got an abs fault flashing up at me??..so wondering if i need to get to holden ASAP, and also with an abs fault what are the major causes for it saying that?. I have had the hpx police pads in it for about 3-4 months dont think they would cause an abs fault and the fluid is all full so anyone got any ideas and solutions?
    Thanks James
    Sticking a Chev badge on any Commodore is like putting a Nissan badge on a VL
    EOI....VE SS 18" wheels x4 with 5000k's on new tread, 2 of have very minimal gutter rash (previous owner) otherwise like new send me a pm if interested.
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    i always randomly get that message on mine n ive taken my vz to my mechanic a few times, and there is no problem just a software issue. although in some cases, you should get it checked. it was giving that message in my mums vz acclaim a few months back, n the wheels kept skidding out of control. best to get it checked so your car doesnt fail on you when driving
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by henrytad View Post
    if it flashes when cranking, and goes away when running, thats a tell tale that your battery is getting weak,
    the fault code that appears then is the low voltage warning at the module
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VE SS, M6
    Nov 2008
    Gold Coast
    so could be the battery going flat?...the car started and chimmed its warning sound and flashed abs fault then went away..never came back on the 15 minute trip home.
    VZ SV6
    Jun 2009
    yer i get the abs fault 99% of the times i drive my car
    im going to change the brake pads soon so hopefully goes away if it doesnt ill pm again
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by claudz View Post
    brake pads have nill effect to the abs system functinality
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    I get the same fault when I switch on my
    HID high beams. Disappears after a few seconds.
    I'm not afraid.
    VE SS, M6
    Nov 2008
    Gold Coast
    so recommendations, take it to holden?..if so how much they cost to get logged codes and check it out roughly?..otherwise let it ride?..it needs a service, and the mechanic is a family friend and qualified holden mechanic so maybe i should let him know and see if he can do anything?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Escape-The-Fate View Post
    has the car got the original battery?
    if it goes away as soon as the motor is running, ill bet 100buck on the battery is getting weak, and really, if it is the original, its doing pretty damm got a 4 years old
    VE SS, M6
    Nov 2008
    Gold Coast
    no idea if its original..i'd say it would be..was a business car for first owner pretty sure and a family car 2nd..now mine.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    black battery with black caps, and a black sticker with red and white writing in that holden font? if so thats the original
    VE SS, M6
    Nov 2008
    Gold Coast
    just had a look..its a black battery..doesnt have any brand names on it but has a white sticker with "superforce" and S46 as battery code..
    VZ SV6 05
    Sep 2008
    mate itll be the battery most likely, i had the same problem for a while, was giving me that fault inconsistently (but always on start up) for maybe a couple months, then my battery went, new battery, never happened again so i would say its the most likely cause, ive heard this issue related to batteries on numerous occasions
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    ok well the superforce is the supercheap auto brand,
    its quite possible the battery has a dead cell and is discharging itself,
    does it consistantly flash on start? or only mornings? etc, try sticking it on the battery charger for an hour on max, then start it, there should be enough surface charge to give it a boost and if the message disappears after that, the battery is on the way out
  15. #15
    VE SS, M6
    Nov 2008
    Gold Coast
    no battery flash on start up, just the normal reds before you hit the key, this morning at 4:30 to go to work got no abs message, also on the way home no message. Will let it ride for a bit and see if the battery dies then ill go get a good quality one if not a drycell..went to the drive-in movies about a month ago and sat through 4 and half hours of movies so thats probably whats killed it. Atleast its nothing major..as the abs still does work tested it today and i will know it was the battery if it goes dead soon.
    cheers for the help
  16. #16
    2005 VZ Wagon
    Sep 2008
    North Shore, NZ
    I'd bet on it being the battery as well.
    I had the same prob, bought a new battery and haven't had the ABS fault flash again.
    Get a new battery mate, it'll save ya getting caught out when it dies eventually
  17. #17
    VZ SVZ
    Sep 2009
    Just chucked in a new battery. ABS fault gone.
  1. ABS fault
    By Timmos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-02-2009, 02:17 PM
  2. Who's at fault?
    By DANNY8 in forum General
    Last Post: 27-03-2007, 02:02 PM
  3. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. Vl Fault
    By Garth in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-03-2004, 01:40 PM
