Results 1 to 16 of 16
Thread: oxygen sensor & exhaust
    mdmatt is offline mdmatt
    2005 LS1 Auto VZ SSZ 328.6rwhp
    Aug 2009
    Default oxygen sensor & exhaust
    Hey guys,
    I recently got a 2 1/2" exhaust system (extractors too) and i've had my engine light come on the other day, and the message was "check powertrain"
    I took it to Holden and they said it was my oxygen sensor, due to my new exhaust.
    Is there anyway of fixing this/getting around it?
    cheers
    227shanno's Avatar
    227shanno is offline Donating Member
    vy ss 5.7
    Aug 2009
    wollongong
    my theory is the car is getting confused due to the sudden difference cuz it thinks you got a normal systen, you could reset the ecu by disconnecting the battery for a few minutes and it should relearn it, if that dosn't work a performance memcal would do the trick
    VZ SV6 && 180sx
    Mar 2008
    From what I understand, it won't be a faulty sensor, but to much airflow going through the sensor, causing the error.
    Holden can clear the error, but it'll most likely come straight back.
    Only true way to stop it from happening is getting a Tune.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    9 times out of ten the coating on the extractors burns off and contaminates the O2 sensors. Did you change your cats too?
    Visit my Facebook page
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    get a vcm suite tune, and remove the fault indicator for the aft oxy sensors,
    did you get new cats aswell?
    highflow or bored out cats will cause the issues
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Thunder SS
    Aug 2008
    hey guys,
    A little bit off topic but close just about to purchase an full exhaust system myself for my L76 ss ute.
    im going di filippo all the way , extractors, cat back and di filippo hi flow cats ( which im presuming are welded up ready to go including the oxy sensor positions by 4 to just bolt on).
    do have to extend the oxy sensor wiring after installing it? if so can you buy the extensions or do you have to make them up?
    i have already accepted the fact ill get the powertrain fault but from what i understand can be deleted by the vcm suite program.
    Apparantly the computer freaks out because of the extra flow and crazy readings it gets from the oxy sensors and thinks the cats are faulty and flashes the error code.
    Any help appreciated.
    cheers
    Aug 2009
    Didn't get new cats no...
    cheers 4 the info, Holden reset the computer so the engine light isn't on at the moment but i was informed it would come back on.
    VZ Crewman S
    Oct 2008
    hey guys how much did you spend on your full exhaust systems? About to start shopping around for a full exhaust for my crewman. Just trying to get an Idea on cost
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Where abouts are you? I can get you a price if you like.
    vz sv6
    Apr 2009
    Quote Originally Posted by mdmatt View Post
    Hey guys,
    cheers
    not sure how many of u have actually asked a exhaust shop about this, but when i got my extractors done the guy explained it to me as that the computer reads the flow output from both O2 sensors and if thats not right but also the O2 sensors have to be the same distance apart as there were from stock or else the same problem will come up so go back to the exhaust shop and see what they gonna do about it VCM only makes the problem show up but the problem is still there and O2 sensors aint cheap if u burn one out
    just my input but when i got my extractors on the guy said that they have to be the same distance and that the cats have to meet the same flow rate as stock as if they flow higher or less the problem will show up again hope this info helps
    VZ Crewman S
    Oct 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Dude I'm over in brissy. I have had 2 quotes so far one for 1900 and the other for 1850. I'm happy with that considering the quotes I recieved about 6 months ago of 2500!
    But yea those quotes are on Pacie extractors, Two high flow cats, 2.5 " single exhaust with a cross flow muffler.
    Aug 2009
    Hey thanks for the info guys.
    About exhausts..
    for my vz ute i got pacemaker extrators, standard cats and twin system 2 1/2" exhaust...
    $1800 installed in perth, full stainless steel.
    06vzcalais is offline Donating Member
    Aug 2009
    just got a quote for pacemakers new system yesterday for the alloytech, drone free ect ect stainless steel from extractors to the tips $3500 installed but that is also including ultima brake pads and instalation with a 25% discount this is pacemakers 2010 release
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    Quote Originally Posted by 06vzcalais View Post
    Shame ill get to test it out befor you ay lol
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    man thats expensive, it'd not want to sound like a rice mobile for that price
  16. #16
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    hmm i never paid that much for any exhaust, good luck.. im so glad i never really had any big problems with my car
    Life starts at 200km/h
  1. oxygen sensor vs
    By Zipster in forum Electrical Wiring / Questions
    Last Post: 29-12-2008, 02:06 PM
  2. Oxygen sensor
    By trevmeister in forum General
    Last Post: 19-11-2006, 01:04 AM
  3. Oxygen Sensor
    By Full Spectrum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2005, 03:40 PM
  4. Exhaust gas oxygen sensor
    By sexypete in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-08-2005, 01:51 PM
