Results 1 to 7 of 7
Thread: where can i find tech specifications....
    VZ SV6
    Dec 2008
    Default where can i find tech specifications....
    i just got a basic diagnosis scanner for my car, so i can do my own fault finding. only problem is i dont know what all this information from the sensors mean, I was just wondering if any one knows where i can get a sensor level specifications data thing on the net, for a zv SV6. I dont wanna get the book for 200 dollars if i can get the information on the net for free
    im trying to work out if my sensors are working the way they should be, before i start replacing things that might not need replacing
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    does your scanner have a section for dtc? thats where you'll find any faults.
    VZ SV6
    Dec 2008
    yeah it does.. but its not displaying any faults....
    my main concern is its drinking to much petrol then normal...
    when i got the car 8 months ago it was running at 11/per 100
    its up to 14.5/ 100k, my driving style hasn’t changed... the guys at the mechanics said it might be oxy sensors... so i got this scanner to check but now i cant understand the damn thing and the mechanic dont know anything about reading the information, i dont wanna go to Holden yet
    Jun 2004
    if an oxy sensor had failed you'd have a dtc logged. that said if your scanner can log the oxy sensors reading it should be reading an afr of 14.7:1 under normal driving conditions.
    some scanners have a oxy test you can run on the sensors mine does.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    VZ SV6
    Dec 2008
    naa it dont have it... its very basic, gives me the readings of every sensor in the car but it dont tell me if its not running the way its ment to or not.... its a sensor reader and a navi, basic dyno all in one... ill show you a log file from it
    VZ SV6
    Dec 2008
    Input Description
    From device: a-GenericOBD2 (a:132) a-GenericOBD2 (a:180) a-GenericOBD2 (a:103) a-GenericOBD2 (a:136) a-GenericOBD2 (a:184) a-GenericOBD2 (a:111) a-GenericOBD2 (a:102) a-GenericOBD2 (a:110) a-GenericOBD2 (a:2) a-GenericOBD2 (a:10) e-GMSpecific (e:224) a-GenericOBD2 (a:9) b-AnalogIn (b:3) a-GenericOBD2 (a:12)
    Name: O2B1S1wr O2B1S1w O2B1S2 O2B2S1wr O2B2S1w O2B2S2 O2B1S2_V O2B2S2_V ECT Speed TOSR RPM VBATT IAT
    Unit: mA % mA % V V ░C kph RPM RPM Volts ░C
    Range: -128 0 0 -128 0 0 0 0 -40 0 0 0 0 -40
    equiv(Sample): 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    to: 128 2 1.3 128 2 1.3 1.3 1.3 215 254.3 8191.9 7000 16 215
    equiv(Sample): 1024 1024 1024 1024 1024 1024 1024 1024 1024 1024 1024 1024 1024 1024
    Color: 13158650 13158650 13158650 13158650 13158650 13158650 13158650 13158650 13158650 16777215 16777215 16777215 16777215 16777215
    -End-
    Session 1
    Time(sec) O2B1S1wr(mA) O2B1S1w O2B1S2(%) O2B2S1wr(mA) O2B2S1w O2B2S2(%) O2B1S2_V(V) O2B2S2_V(V) ECT(░C) Speed(kph) TOSR(RPM) RPM(RPM) VBATT(Volts) IAT(░C)
    0 0.019531 1.008696 1.275 0 1.00284 1.275 0.435 0.435 83 0 0 599.25 13.81 33
    0.082 0.019531 1.008696 1.275 -0.015625 0.998692 1.275 0.44 0.435 83 0 0 594.25 13.97 33
    0.164 0.015625 1.007232 1.275 -0.015625 0.999912 1.275 0.44 0.435 83 0 0 589.5 13.97 33
    0.246 0.015625 1.00772 1.275 -0.007813 0.999668 1.275 0.435 0.435 83 0 0 588.75 13.94 33
    0.328 0.015625 1.00772 1.275 -0.003906 1.001132 1.275 0.435 0.435 83 0 0 597.5 13.94 33
    0.41 0.015625 1.007476 1.275 -0.003906 1.002596 1.275 0.435 0.435 83 0 0 598 13.7 33
    thats only a few secconds... you need to streach it out... its a cut and paist from EXCEL!
  1. VN......VP Specifications
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2008, 09:59 AM
  2. V6 Camshaft Specifications
    By beardy91 in forum V6 Development And Modification
    Last Post: 09-11-2007, 05:48 PM
  3. VH/VK V8 Tune-Up Specifications
    By daggett in forum Holden Commodore How-To's
    Last Post: 30-12-2006, 07:11 PM
  4. specifications on the gts
    By jbarr in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-09-2006, 04:01 PM
  5. VB Specifications
    By Milton Young in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-01-2005, 04:52 PM
