Results 1 to 10 of 10
Thread: VZ ECM anti abuse mechanism
    VZ executive 3.6
    Aug 2009
    Default VZ ECM anti abuse mechanism
    i'd like to make it clear i am not a hoon.
    Recently i was told on this site about the ant abuse stuff in VZ 175KW engines now i'm thinking that anti abuse device probably gets its throttle reading from the throttle positioning sensor, is that right?
    VZ executive 3.6
    Aug 2009
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    VZ executive 3.6
    Aug 2009
    i was thinking that if i was to disconcect the throttle position sensor (tps) , then the ecu wouldn't able to tell whether i was on the throttle while on the brake and there for, not interfere
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    there is no TPS as such, its fly by wire, any tampering with the wiring will fault the system.
    not a clever idea
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    the major of the anti abuse comes from engine load which is measured by the MAF. but unplugging the MAF will put the car in limp mode not sure how this affects power delivery.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would take a guess saying that you can turn it off properly, if you take it to a tuner.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Yes it probably can be de-activated, that's if you're happy to drive around in permanent 'limp mode'.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by Benboy View Post
    not if its done properly same approach with the anti-theift protection
    Jun 2004
    you can deactivate some of the anti abuse but you'll never fully get all the torque management as it's the back bone of the bosch software.
  1. anti abuse mode ?
    By cookp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2012, 05:18 PM
  2. need a new VL power window mechanism...can anyone help!
    By CuttsCalaisVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-02-2009, 06:46 AM
  3. locking mechanism
    By marilynk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2009, 08:42 PM
  4. VS ute window mechanism
    By radbeck in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 05:03 PM
  5. Anti Abuse
    By ssteveO in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-10-2005, 07:43 AM
