Results 1 to 8 of 8
Thread: VZ alloytec codes
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Default VZ alloytec codes
    P0008 - Engine Position Performance Bank 1
    P0009 - Engine Position Performance Bank 2
    P0016 - Crankshaft / Intake Camshaft Position Not Plausible Bank 1
    P0017 - Crankshaft / Exhaust Camshaft Position Not Plausible Bank 1
    P0018 - Crankshaft / Intake Camshaft Position Not Plausible Bank 2
    P0019 - Crankshaft / Exhaust Camshaft Position Not Plausible Bank 2
    P0112 - Intake Air Temperature Sensor Circuit Low Voltage
    P0113 - Intake Air Temperature Sensor Circuit High Voltage
    P0117 - Engine Coolant Temperature Sensor Low Voltage
    P0118 - Engine Coolant Temperature Sensor High Voltage
    P0125 - Insufficient Engine Coolant Temperature for Closed Loop Fuel Control
    P0196 - Engine Oil Temperature Sensor Circuit Range / Performance
    P0197 - Engine Oil Temperature Sensor Low Voltage
    P0198 - Engine Oil Temperature Sensor High Voltage
    P0261 - Fuel Injector #1 Short to Ground
    P0262 - Fuel Injector #1 Short to Power
    P0264 - Fuel Injector #2 Short to Ground
    P0265 - Fuel Injector #2 Short to Power
    P0267 - Fuel Injector #3 Short to Ground
    P0268 - Fuel Injector #3 Short to Power
    P0270 - Fuel Injector #4 Short to Ground
    PO271 - Fuel Injector #4 Short to Power
    PO273 - Fuel Injector #5 Short to Ground
    PO274 - Fuel Injector #5 Short to Power
    PO276 - Fuel Injector #6 Short to Ground
    PO277 - Fuel Injector #6 Short to Power
    PO327 - Knock Sensor Bank 1 Circuit low Frequency
    PO328 - Knock Sensor Bank 1 Circuit High
    PO332 - Knock Sensor Bank :2 Circuit low Frequency
    PO333 - Knock Sensor Bank 2 Circuit High Frequency
    PO335 - Crankshaft Position Sensor Circuit
    PO336 - Crankshaft Position Sensor Signal Range / Performance
    PO337 - Crankshaft Position Sensor Circuit low Duty Cycle
    PO338 - Crankshaft Position Sensor Circuit High Duty Cycle
    PO341 - Camshaft Position Sensor Malfunction
    PO342 - Camshaft Position Sensor Voltage low
    PO343 - Camshaft Position Sensor Malfunction
    PO346 - Camshaft Position Sensor Malfunction
    PO347 - Camshaft Position Sensor Voltage low
    PO348 - Camshaft Position Sensor Malfunction
    PO366 - Camshaft Position Sensor Malfunction
    PO367 - Camshaft Position Sensor Voltage low
    PO368 - Camshaft Position Sensor Malfunction
    PO391 - Camshaft Position Sensor Malfunction
    PO392 - Camshaft Position Sensor Voltage Low
    PO393 - Camshaft Position Sensor Malfunction
    PO443 - Canister Purge Solenoid Circuit Malfunction
    PO458 - Canister Purge Solenoid Circuit Low Voltage
    PO459 - Canister Purge Solenoid Circuit High Voltage
    P0504 - Brake Switch Circuit Malfunction
    P0521 - Engine Oil Pressure Sensor Circuit Range /Performance
    P0522 - Engine Oil Pressure Sensor Circuit Low Voltage
    P0523 - Engine Oil Pressure Sensor Circuit High Voltage
    P0560 - ECM Battery Supply Voltage Out of Range
    P0562 - ECM Battery Supply Voltage <11 Volts for 5 Seconds
    P0563 - ECM Battery Supply Voltage >16 Volts
    P0615 - Starter Relay Control Circuit Faulty
    P0616 - Starter Relay Control Circuit High Voltage
    P0617 - Starter Relay Control Circuit Low Voltage
    P0625 - Generator F Terminal Low Voltage
    P0626 - Generator F Terminal High Voltage
    P0627 - Fuel Pump Relay Malfunction
    P0628 - Fuel Pump Relay Malfunction
    P0629 - Fuel Pump Relay Malfunction
    P0685 - Main (Engine Control) Relay Malfunction
    P0686 - Main (Engine Control) Relay Circuit Low Voltage
    P0687 - Main (Engine Control) Relay Circuit High Voltage
    P1258 - Engine Coolant Over-temperature Protection Mode Active
    P1668 - Generator L Terminal Circuit Malfunction
    P2105 - ECM Voltage Supply Incorrect
    P2227 - Barometric Air Pressure Sensor Range / Performance
    P2228 - Barometric Air Pressure Sensor Low Voltage
    P2229 - Barometric Air Pressure Sensor High Voltage
    P2251 - Oxygen Sensor Signal Changes >10Mv as Heater Control Switches
    P2254 - Oxygen Sensor Signal Changes >10Mv as Heater Control Switches
    P2500 - Generator L Terminal Circuit Low Voltage
    P2501 - Generator L Terminal Circuit High Voltage
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VZ SV6's Avatar
    VZ SV6 is offline 2005 VZ SV6
    VZ SV6 190kw & VZ Acclaim
    Jul 2009
    Brisbane QLD
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by VZ SV6 View Post
    Thanks very much for posting these. Where did you get them from?
    i'd rather not say.
    Powered By Garrett
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Torquative View Post
    trial and error aye Chris
    well since i'm semi retired LOL.
    i got a lot of softwear from my last employer (nothin illegal).
    and as well as my own cnc softwear which is licenced to me.
    Powered By Garrett
    Torquative's Avatar
    Jun 2005
    i wouldve went for the "stuck paperclips in various holes and worked out what blew from there" but what you said sounds just as good
    vz sv6
    Jan 2009
    sweet, so what are these for? lol
    just if your lcd show these codes you know what it is?
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    25 pages of codes here... been on the net for yrs
    need tech 2 or alike to read the codes
    Attached Files Attached Files
  1. Alloytec v6
    By MICKY.D in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-06-2009, 03:14 PM
  2. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  3. [VIC] or [AUS] Wtb: Ve alloytec maf
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 17-02-2009, 11:37 AM
  4. Alloytec 190 into a VN S1 V6
    By savage1987 in forum V6 Development And Modification
    Last Post: 22-06-2008, 11:06 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
