VZ Adventra Steering Rack replacement
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
My rack apparently needs to be replaced at 78000 km - priced at between $660 and $1000 fitted. Lowest price at Pedders.
Seems this is a different rack to standard Commodore.
Does this sound OK? Or can the steering arms be tightened up in some way?
Thanks in advance.
PS have replaced strut bushes and sway bar links are tight.
wetwork65
A wet business
Thanks - yeah holden dealer approx $700. Clunking when turning hard, parking and low speed turns eg roundabouts - and have checked/replaced everything else
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
have they greased the small bump stops? where the hub meets the lowercontrol arm? if these are dry, it will make a clunk noise on full lock over small undulations in the road surface
wetwork65
A wet business
Hmmm - thanks, will look at this as well.
Benboy
Hill River, SA
2007 SVZ Wagon
Check ALL suspension pivot points (bushes, joints etc) before replacing steering rack.
vzberlinav6
vz berlina v6
i had the problem of clunking when turning ended up being just a strut bearing
wetwork65
A wet business
Oh and Pedders Mandurah (bless them - at last :bow:) were the first place to find the source of the ******* annoying steering klonks at full lock - the rack holding bolts needed tightening.
This source of noise has been covered many times before on this and other forums and would have been obvious for any decent workshop to check.
I had asked various workshops to check these, but like so many other things in SW WA had not been taken seriously.:bang:
Pete_perth
Pedro
VZ Adventra CX6
Sorry to revive an old thread, but does anyone know the torque setting for the bolts that hold the steering rack in place? Many thanks :)
