Hey guys,
Has anyone changed there standard headlights on a VZ to the projector headlights like on the SS.
Was it difficult to change? and did you put HID in.
Any feed back welcome
Thanks
Harvs01
They were easy as to change. Just use the front bumper removal guide at the top of the VZ forum. Once the front is off you will find 3 bolts, undo them and pop the light out. Undo the plug and reverse with the new lights.
Like Troy said, very easy to changeover.
The existing wiring harness clips straight into the SS lights, simple as.
When i did mine when i hit hight beam, low beam bulbs wud go out, were low beams r ment to stay on when on high beam.I took it to auto electrician, 80 bucks fixed the problem, there is a link on here sum were on how to do it ur self.
