Results 1 to 5 of 5
Thread: need help understanding
    VZ Clubsport Kit
    Mar 2009
    Default need help understanding
    i may sound dumb but i gotta ask, when you talk bout diffs being 4.11 or 3.45.Which onw will produce more power?is it the higher the number or what?thanks guys
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    the higher the ratio, the shorter the gears. 4.11's will rev out quicker and increase acceleration, but you lose top speed.
    VZ Clubsport Kit
    Mar 2009
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    If it carried over from VX etc, it will be 3.07 to one. That is a ratio designed for economy, by keeping engine revs low at cruising speeds. It will not assist acceleration - if you want faster acceleration, but are prepared to put up with more revs, engine noise and lower fuel economy, you need to swap it for a 3.46 or 3.73 ratio.
    Incidentally, diff ratios do not produce more power. They simply permit the engine to give faster take-offs and rev through the ratios more quickly, because you have effectively lowered the gearing through all gears. Top speed in each gear will be lower, but the car will get there quicker.
    VZ Clubsport Kit
    Mar 2009
    ok cheers thanks heaps
  1. understanding VZ vin codes?
    By devi8vk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-05-2011, 08:18 AM
  2. Understanding Engineers
    By Reaper in forum Jokes/Humour
    Last Post: 15-06-2008, 12:50 AM
  3. not really understanding ebay
    By Burnout_bro in forum The Pub
    Last Post: 12-12-2007, 11:50 PM
  4. I need help with understanding features of my VS
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2005, 08:50 PM
  5. Understanding Kiwis
    By fourstar82 in forum Jokes/Humour
    Last Post: 31-07-2005, 11:00 PM
