Results 1 to 3 of 3
Thread: Small light above rear passenger door
    VZ Executive
    Aug 2009
    Default Small light above rear passenger door
    Hi all,
    There is a small light inside the car just above each rear passenger door, and one of mine seems to have died, and I was wondering how I would go about replacing this myself?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    What do you mean, the light or the globe? If the globe, then you should find adequate instructions in the Owner's Handbook, usually found in the glovebox of the car. If the light needs replacing, follow instructions for removing globe then undo retaining screws used to secure light to body.
    monochrome's Avatar
    monochrome is offline Yeah.....what?
    VZ acclaim
    Aug 2009
    Langwarrin, VIC
    you should be able to pry the light cover off with a flathead screwdriver. then you can just pop the globe out and replace it. thats how i did it anyway
  1. VT rear passenger door problem
    By panda88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2008, 01:29 PM
  2. Rear passenger door problem
    Last Post: 28-05-2008, 01:12 PM
  3. Rear passenger door not locking
    By Jxarm in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2007, 12:28 AM
  4. Locked rear passenger door
    By Lurch in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-02-2006, 10:48 PM
