After an unfortunate incident in which some complete tool nearly drove into me when trying to pull into a park, I ended up grinding the left front rim against the gutter. Its prompted me to consider replacing two of my rims, as the other was damaged before I bought the car.
My plan at this stage is to replace the rims; keeping the old rims and using the best of the two with a new tyre as the spare. The spare at the moment, as with most factory issued spares that I have seen, is not a low profile tyre.
I have surfed the web and only found one place so far that stocks the genuine GMH rim, which is Wheel King; asking $325 for the rim by itself.
Does anyone know anywhere else where I can get these rims from? (Preferably near QLD to lower postage costs). Thanks.
Yeah I have been looking through Ebay over the last few days, but have not found any which are the same as mine as yet...
I don't know if it would be worth looking at a wreckers either, as I'm sure they would strip the mags off before they hit the yard. Might still be worth a look though??
a lot of clients at work get their rims repaired through a mobile bumper repair guy. may work out cheaper this way?
I thought about that also, but there would be a lot of work involved in buffing the surface down to make it smooth again.
Is the repaired section very noticable on any wheels you have seen fixed?
That's one of mine I had repaired. The pics are shit but it turned out awesome. Cost 130 bucks.
Hey troy what wheels do you have and where did you buy them? Exactly what i am looking for!
As for the OP i have a set of 4 17" rims here (same type off vz s pack) if your interested in buying them, i plan on getting new rims soon.
pm me
vz sv6, when you get new tyres make sure the fool that balances the wheels put stick on weights on the inside of the rim, rather than hammering the weights to the outside edge
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Thanks for the advice. I'll keep in touch with you GTRwilson about your rims.
