Results 1 to 7 of 7
Thread: Possible things causing SRS Fault?
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Default Possible things causing SRS Fault?
    Hello,
    Ok so let me explain what happened first. I was swapping steering wheels and broke the clock spring (dumb) Then of course when i turn the car on it set off the srs light. Since then i have replaced the clock spring and i know its working as the horn and audio controls are working perfect where as before nothing worked! I then went to get the srs light reset with a scan tool from my local mechanic but he said that it keeps reseting. Is it possible to have audio controls and horn but no airbag running through the single clock spring? I would think if its broken in one area the whole lot would go? To top it off they said 500 to fix it! get stuffed! Clock springs go for $20 bucks on ebay.
    My question is is there anything else i could have done to set off the light playing with the wheel?
    Also what other things could set off the light? I know there are seat belt pretensioners and i plan to check them next. But is there something else i am missing?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    did they tell you what the fault was?
    could be coincidence, or maybe you shorted something out which may have spiked the srs module?
    lil more infor needed
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Thats just it mate the only thing they said is wrong is the clock spring! no way that should cost $500!
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Ok so if the clcok spring was broken. Would the audio controls and horn still work but the airbag not? Also to clear the faults if i buy this :
    OBD2/EOBD SCAN TOOL OBD VY VZ VE GEN3 LS1 LS2 V6 GS500 - eBay Hand Tools, Tools, Car Parts, Accessories, Cars, Bikes, Boats. (end time 18-Sep-09 17:04:30 AEST)
    Would i be able to reset the SRS fault code myself?
    cheers
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    The scantool in question should work for you.
    Email vender to be sure.
    It's the same brand as the one I use.
    I'm not afraid.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    all the ones Ive played with tell you whats causing the fault (I cant view the ebay link at work).
    If its not perhaps you need to find someone whose machine is capable of reading the fault codes because it will tell you spot on whats caused the SRS fault
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Torq do you mean it will say the fault is in a certain airbag? eg steering wheel or seat belt pretensioner?
  1. computers causing different cranking
    By rappa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2009, 07:19 PM
  2. magnet causing problems?
    By miltiadis_s in forum General
    Last Post: 01-12-2008, 09:23 PM
  3. Whats causing the beeping!!?
    By PsYko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 01:12 AM
  4. PCM causing MAT problems
    By srey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 04:19 PM
  5. stereo causing problems i think
    By russ in forum Car Audio
    Last Post: 30-10-2004, 08:13 PM
