hey guys,
driving home from work today i gave the girl a bit at a set of lights. Between mid - high revs under hard acceleration its almost as if the car is shuddering, as if a wheel is loose. Could almost be explained as when your rotors need machining and you brake hard a similiar effect to that but in the rear end (maybe left side)
any suggestions, i have been told it could be CV's or Diff?
Life starts at 200km/h
thanks for the input guysturns out it was the Tailshaft Rubber
Damn, i was gonna ask if you lost traction, haha.
Was the donut visibly damaged/rooted ? i have the same thing but donut looks to be fine (mine and workshops opinion)
donut has been changed... but problem still there
gonna have a look today... thinking tailshaft bearing...tailshaft weight...
havent been for a drive in the car yet tho..
'original' "donut" is fingered.. crack between the holes and bends heaps.. if yours is doing the same thing i would put it up and have a look, may have to remove the zorst but its definatley worth it.. it may not look stuffed but upon further inspection you will find defects..
Pretty much like the clutch im guessing, 'made to break' time for another one!!
Rubber Tailshaft coupling is the correct name for it!
wouldnt buy or recommend a generic rubber coupling from bursons/repco to anyone anymore
GO FACTORY!
this is impulsives...lasted bout 1 week...
i bet bigdaddycool has enough power to do this daily!!!
lol i got a couple genuine ones sitting at home if you wanna buy them mate, pm me if you wanna know,
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
replaced it this arvo, ill definately hook you up if it goes again, hopefully this one will last though.. further to this i just drove home bout 70km no drama's yet god fordbidding.. hopefully it holds up this time
i should of painted the new one in, get a few more KW outta it hey Bigdaddycool!?
whats the factory one worth? part number?
I believe it's worth about $150 brand new, try calling around if you need one, if you need a hand replacing one let me know im an expert now![]()
