Pictures of Inside a VZ BCM
bigdaddycool
Brisbane, Queensland
2009 VE SS SILVER SEDAN
Unforunately I'm not at my dad's car where I can pull the BCM out and check it out.
Does anyone have pictures of what it looks like inside? for any VZ BCM.
I just wish to view it to have a look at possible points of failure. I get the feeling his BCM is faulty or possibly a earth around the car.... trying to same time if I can get a picture to rule out failure by bad design.
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
hey anyman you mind if i put a copy of that pic on our delco forum someone might find that handy
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
cheers mate
bigdaddycool
Cheers Andy. I just wanted to see the design layout. I've been told the ECU is sealed? Is it or do you have any pictures of that inside too?
andyman
34
Orange, NSW
ecm is a sealed sandwich unit, so there is 2 circuit boards side by side in there, i think its then filled with resin so it cant short out, i think thats how they work
bigdaddycool
just wondering if there's any capacitors in there......... being mounted on the engine n all ......... in terms of an accident a power spike could possibly cause them to blow. looking at options atm with reguards to a head on crash issue we have with another vz
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
anyone know which relay in the picture in this thread of the bcm internals is the one that sticks and causes the indicators to stay on when you lock the car? and can you fix it by just cleaning the contact or does the whole relay need replacing?I think its the smaller relay that is the only one of its type in the picture.
