Results 1 to 5 of 5
Thread: Check Powertrain Warning Light
    VZ 6.0 SS Thunder
    Jul 2009
    Exclamation Check Powertrain Warning Light
    Hi guys, I have a vz ss and just put a new full exhaust on it. Drove it about 500ks and then the "check powertrain" warning message came up. I disconnected the battery and after reconnecting the light was off then came back on not long after. Just wondering what this means, something to do with the O2 sensors? Any comments would be much appreciated, cheers.
    mdmatt is offline mdmatt
    2005 LS1 Auto VZ SSZ 328.6rwhp
    Aug 2009
    I had the same issue when i put a full system on my v6 ute.. yeah its to do with the o2 sensors.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    i take it you had cats done, to get rid of the message youll need to get a tune and get the rear oxygen sensors disabled, problem is, highflow cats dont fully burn the excess fuel, or its burning is different to the standard cats, so the oxygen sensors arnt reading as its sposed to
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ SS MY06 L76
    Jul 2009
    I have a VZ SS 6L with the same problem, have taken it to numerous holden dealers and still have not fixed it. I have found out more info about this problem from people on this forum then i ever will from holdens. I have been told it requires a retune. I have learnt to deal with the warning after 12 months now, but it is still a pain in the arse. I am not sure whether the L98 6L motors have the same issue or is it just the L76 6L. Let us know if you manage to fix it, i am eager to find out.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Checekiam View Post
    any alloytec or v8 with the 4 oxy sensors will do it unless the factory cat converters are retained
  1. Powertrain warning light
    By VT2VEight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2012, 05:20 PM
  2. Check Enigine warning light.
    By Tiger28 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-04-2009, 10:46 AM
  3. Airbag warning light after headers install and brake check??
    By Curtisb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2009, 12:07 AM
  4. Check Powertrain warning message
    By Luke0011 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-03-2009, 01:41 AM
  5. VT SS, Powertrain warning light.
    By dissident in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2005, 03:01 PM
