Results 1 to 6 of 6
Thread: Alarm problem
    vz berlina v6
    Aug 2007
    Default Alarm problem
    whenever i put my alarm on the horn goes off a few times, anyone have any ideas?
    the only thing ive done recently is change my stop light globe. thanks
    06vzcalais is offline Donating Member
    Aug 2009
    you can change this thu the optionsmenu when you turn your ignition on after the system check press the up or down button as dirrected on your display till you get to the door lock indications option the press up or down till it comes to indicators them whala problem solved
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    does all the doors lock? does it chirp when you press the button once? doess it beep when you press it tcie to deadlock?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vz berlina v6
    Aug 2007
    when i lock it once it does it havent tried twice. i normally lock it twice though
    VP SS
    Jan 2008
    Hiding in WA somewhere
    check if all doors a locking mine did this and back door wasnt locking usually means the acuator is needs replacing
    If its got Wheels or Boobs its gonna cost ya money
    vz berlina v6
    Aug 2007
    took it today to steinborner gawler where i bought it. they replaced the actuator, checked before i left was ok, then i got home locked the doors and same problem happening again. now have to make another trip back there pretty pissed off.
  1. vx alarm problem
    By jamierobbo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2009, 10:10 PM
  2. car alarm.
    By Humm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 01:37 AM
  3. VR 5.0 Alarm problem?/not starting
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2008, 07:33 PM
  4. Car Alarm
    By Trei in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2007, 09:28 AM
  5. which alarm
    By fastvs in forum Electrical Wiring / Questions
    Last Post: 30-12-2005, 12:55 PM
