Results 1 to 4 of 4
Thread: VZ manual aircon/heater problem
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Smile VZ manual aircon/heater problem
    I know that this problem has been raised in the VT Commodore forum, but I have an issue with my aircon/heater system, where the air vent switches over to full demist under heavy acceleration. Further, the floor/demist position doesn't seem to be working correctly, as all the air comes out the demist vents. Any suggestions?
    Also, someone posted a diagram of a HVAC unit on these forums, but it seems to be a slightly different unit to my VZ HVAC, as the vacuum solenoid pack doesn't seem to be fitted adjacent to the blower housing. Having a quick look, the colored vacuum lines to the actuators appear to disappear to the top front of the HVAC unit. Can someone please confirm the location of the vacuum solenoid pack on the VZ HVAC unit, and what dash items have to be removed to gain access to the vacuum solenoid pack & vacuum actuators?
    TIA
    Black VZ SV6
    Dec 2005
    Hi TIA,
    i also have this problem since putting a blower onto my engine.
    dont know if it was caused by that, but it has had me scratching my head for months
    Drive it
    Like ya stole it!
    Sep 2009
    Default VZ manual aircon/heater problem
    Just an update if anyone is interested, I have found the cause of the problem. One of the diaphragms in the demist/foot vacuum actuator has completely torn. Unfortunately, Holden have nil stocks of new vacuum actuators Aust wide - with new stock apparently not due until Nov.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    jaisvz is also probably because of the lack of vacuum in his motor when the throttle is open,
    maybe a seperate vacuum pump attached to the hvac unit vacuum line would work better for you
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. VK heater / aircon.
    By streetholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-05-2009, 05:11 PM
  2. VY heater , aircon controls
    By putz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2009, 11:33 AM
  3. heater / aircon fan troubles (VS II)
    By oz-fr in forum Electrical Wiring / Questions
    Last Post: 27-05-2008, 08:48 PM
  4. Heater/AirCon Fan!
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 05:25 PM
  5. VS heater aircon problem HELP!!!
    By Joecoxon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2005, 02:49 AM
