Results 1 to 12 of 12
Thread: coolent mixture
    az_sv6's Avatar
    az_sv6 is offline coudnt aford a v8
    vz sv6
    Sep 2009
    western sydney
    Question coolent mixture
    on the vz alloytec it has a coolent bottle next to the cai.
    the question is do you mix the coolent or do you poor just coolent?
    if so whats a good mixture.
    prob a stupid question but just thought id ask..
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    depends what you buy, most are just an 'additive' as in you need to mix water with it, and it should say on the bottle the ratio..
    if you get a 'premix' then you pour it straight in.. as for where you pour the stuff in, your spot on, in the Coolant resivior it goes..
    Life starts at 200km/h
    Black VZ SV6
    Dec 2005
    just changed my coolant last week,
    Tectaloy ... um alloy something... its red and about 20 bucks at repco for the concentrate 500ml bottle which makes up 15 litres when watre is added.
    Vz cooling system takes 10-11litres from memory. (14 as ben points out below)
    Drop your bottom radiator hose, let old coolant run out, then stick a garden hose in there and give it a good backwash.
    Connect bottom radiator hose back up, and undo the bleeder on the top left of radiator. (will need to remove shroud to do this.)
    Undo the yellow coolant cap on the radiator and pour in about 3/4 of the coolant concentrate.
    Add water to fill until you see it leek from the bleeder.
    Tighten bleeder and replace yellow cap. Fire up the engine and crack the bleeder a small amount just to let any trapped air escape. If coolant just floods up it should be fine, just tighten up again.
    You may need to open yellow cap again just to top up with a bit more water, make sure engine is off when you do this... the water system is extremely pressurized.
    Put your shroud back on then your done!
    Drive it
    Like ya stole it!
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Suggest that you buy and use only the correct coolant for the Alloytec engine. Check your Owner's Handbook for specific details of which coolant to use. To do otherwise is inviting problems. The following is from the Tectalloy website:
    TECTALOY XP7 RED
    Tectaloy XP7 Red is specifically formulated as a replacement for any factory fill red coolant more commonly found in late model vehicles. It is easily identified by its distinctive colour. Tectaloy XP7 Red is a premium silicate free glycol based Anti Freeze/Anti Boil providing long term corrosion protection with excellent heat transfer properties. The product contains a colour change warning feature should the coolant require changing prior to the scheduled service period, the coolant can vary in colour from red when functional to yellow if a change is required.
    This product can be used as either a complete fill or further diluted by adding 1lt of demineralised water to every 2lts of coolant. This will result in a 33% Anti Freeze level.
    The advice given to mix 500ml with 14.5 litres of water is incorrect. If you are using Tectaloy, 500 ml of additive will only make up to 1.5 litres of coolant. The ratio is 1 litre of additive to 2 litres of DEMINERALISED WATER ......DO NOT USE TAP WATER as it MAY contain TOO many unwanted minerals.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    alloytechs use the same stuff as the gen 3's, i've got tectaloy vplus orange
    Chev badges are an instant fail
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    I just put whatever mercedes benz use in my car.
    Pro's of servicing your own car at a mercedes dealership
    Black VZ SV6
    Dec 2005
    no 500ml is correct, i am using the super concentrate version
    Drive it
    Like ya stole it!
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Quote Originally Posted by jaisvz View Post
    Have checked the Tectaloy Website.
    The only product you should have used is
    TECTALOY V PLUS ORANGE
    I don't think this is super concentrate.
    Please explain.
    I'm not afraid.
    Black VZ SV6
    Dec 2005
    the product i used isn't even on the website. maybe it may be new to the range.
    It is formulated especially for alloy blocks.
    Drive it
    Like ya stole it!
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    dex cool from holden for 30bucks for 5l concentrate is what i used, you dont have to worry about mixing coolents then either
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i just replaced my front bar for $250 had a nice towball dent in the front.. but personally if the damage aint too bad get it repaired, they can match paint and fix that stuff like new!
    Black VZ SV6
    Dec 2005
    oops wrong thread impulsive :P
    Drive it
    Like ya stole it!
  1. Air Fuel Mixture Gauge
    By COMMY VP 666 in forum Electrical Wiring / Questions
    Last Post: 05-03-2009, 10:39 PM
  2. Nitrous and LS1 mixture!
    By chappy in forum LSx Development and Modification
    Last Post: 10-04-2007, 04:38 PM
  3. mixture and idle
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 01:55 PM
  4. Heavy Mixture
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2006, 05:30 PM
  5. Jaycar Mixture Display Kit
    By Snotty in forum Electrical Wiring / Questions
    Last Post: 04-02-2006, 10:44 PM
