Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: sv6 auto remote car start... question
    VZ SV6
    Aug 2006
    Default sv6 auto remote car start... question
    hi..
    i have viper remote start system 5301 to install it in my car .. do i have to obtain the bypass module??
    if yes which one should i buy?
    this one can work for example?
    GM Remote Start Bypass Interface Module DEI 555LW
    thanks
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    one guy recently had one like that fitted to his car, it made a few issues with the imboliser.. personally i wouldnt install them
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ SV6
    Aug 2006
    thx but it should be a way to maintain the integrate of the immobilizer and the remote start system ..
    it's very handy fo me as i live in a hot weather area
    VZ SV6
    Aug 2006
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    any help would be great as i need to find out about a bypass as well. to remote start mine, i gotta unlock with the holden key then remote start. n itll turn off in like 20 secs because the imobolizer kicks in.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by henrytad View Post
    youll find it hard to do it as the bcm uses the code from the standard key to recognise its the owner and then unlocks it, you could get the aftermarket to unlock the car, but more than likely the alarm will go off when you open the door
    VZ SV6
    Aug 2006
    Jun 2009
    Castle Hill, Sydney
    VZ SV6
    Aug 2006
    Quote Originally Posted by andyman View Post
    maybe thats why the tech told me about door lock module + IMMOBILIZER bypass
    i'm not sure about it maybe i should wait till i know how it should be done from someone here before i give it a try
    Jun 2009
    Castle Hill, Sydney
    any news from anyone? i was thinking what if one of us purchase it and try it, depending on if its reversible installation if it screws the car up?
    VZ SV6
    Aug 2006
    the tech man will contact me tomorow about the bypass .. Will tell you by then
    Jun 2009
    Castle Hill, Sydney
    VZ SV6
    Aug 2006
    cheers man
    bad news the tech told me it can't be done now as the directed told him the commodore is not available in US
    maybe some one can give me an information about the security system and i'll forward it to the tech?
    Jun 2009
    Castle Hill, Sydney
    but wouldnt it b like a standard gm thing, theyve got the lumina up in the us which basically is the commodore
  15. #15
    vx executive 3.8
    Sep 2009
    does anyone have any idea how to bypass the immobiliser for the remote start to work without unlocking the car with the factory remote first?
  16. #16
    VZ SV6
    Aug 2006
    they got the monaro + the VE commodore just what is the GM security system in the commodore?
    General Motors Anti-theft Systems:
    Many late-model GM vehicles are equipped with
    one of three basic anti-theft systems; Passkey,
    Passlock, and Passkey 3. Standard Passkey
    systems are easily identified by the resistor chip
    visible on the shaft of the key. Passlock systems
    do not rely on a resistor equipped key. Instead
    they use a resistance code generated when the
    key is turned in the ignition cylinder. Both of
    these systems have an anti-theft indicator in the
    instrument cluster. To properly interface into
    these systems and retain full functionality of the
    factory anti-theft system, use the APV-1 module.
    The Passkey 3 system, which is found on GM
    vehicles 1999 and newer, is a transponder based
    system (described below). Use the APP-1
    module to integrate into Passkey 3 equipped
    vehicles. This module allows full functionality of
    the factory anti-theft system and requires the
    use of a spare key.
  17. #17
    Jun 2009
    Castle Hill, Sydney
    its either the first or the second one. does anyone else out there no? come on guys we need everyones help, i know theres people out there with commodores that have 100% remote start functionality and they bypass the immobolizer. your help is needed
  18. #18
    vx executive 3.8
    Sep 2009
    i got a vx 2002 my remote start works but i gota unlock my car with factory key first. you think a module would bypass it? anyone?
  19. #19
    VZ SV6
    Aug 2006
    the tech told me today it can't be done.. so i'm thinking to disable the immobilizer in my car so i shouldn't need the bypass.
    the passkey 3 is
    Passive Transponder Systems:
    Passive transponder systems have become the
    most popular anti-theft system among vehicle
    manufacturers (Ford, Honda, BMW, Toyota,Nissan and others). This system requires use of
    a tiny passive transmitter housed in the base of
    the key. This device activates when placed close
    to the vehicle’s ignition switch. The starter will
    usually crank but the fuel system will be disabled,
    mot allowing the vehicle to run, if the
    transponder is not detected. To properly
    interface into transponder systems, use
    the APP-1 module. This module allows full
    functionality of the factory anti-theft system and
    requires the use of a spare key.
    maybe it is the passkey 3 ?
  20. #20
    Jun 2009
    Castle Hill, Sydney
    i wanna disable mine too, besides the aftermarket alarm already acts as an immobolizer too which i reckon is more powerful as well.. what do you guys know about disabling the immobolizer in a vz?
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
  21. #21
    VZ SV6
    Aug 2006
    i booked my car to be checked in Saturday the tech told me maybe it could affect other things in my car but till then.. we will wait to others responds
  22. #22
    Jun 2009
    Castle Hill, Sydney
    yeh i heard about that too, as long as you get a proper answer from a pro then youll know. its not worth stuffin around with something that you cant fix bak if u dont know the consequences. goodluck i guess, hopefully its something that can b done
  23. #23
    VZ SV6
    Aug 2006
    i went to the workshop yesterday ... it was a nice place and the people there was very helpful.
    he got the wiring diagram for the pontiac GTO 2005 but he said it is different than vz ... im not sure about this would someone confirm this?
    our last chance is to ask directed Australia they should know about vz better than directed America.
    should get a call on Tuesday
  24. #24
    Jun 2009
    Castle Hill, Sydney
    goodluck
  25. #25
    VZ SV6
    Aug 2006
    just arrived from the dealer... they said they can't disable the immobilizer cuz the car will not start as it is a main part of the security system.
  1. Remote engine start on VXII berlina with factory key remote
    By cougar1985 in forum Electrical Wiring / Questions
    Last Post: 02-11-2010, 01:32 PM
  2. Vt remote engine start question
    By fatboy15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2009, 10:45 PM
  3. remote start
    By drippy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2008, 08:12 PM
  4. remote start in S1 VT??
    By roger05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2008, 08:33 PM
  5. Remote Start on 308....
    By GOTMYN in forum General
    Last Post: 23-01-2008, 04:55 PM
