Results 1 to 5 of 5
Thread: VZ Fuel Guage Error - Wont Start - Conclusion
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Default VZ Fuel Guage Error - Wont Start - Conclusion
    For those who know about our 2005 VZ Executive project we've been working on here. We have a 2005 VZ Executive which was involved in a accident prior to purchasing it (front on collision under a truck)
    We've been restoring it, during the process we were plauged with a Fuel Guage Error issue preventing the car from starting, having to short the starter relay to jump it. We messed around for along time with the ECU via VCM Suite to track down what was causing the immobiliser to be set off when it would not start.
    We tried disabling different sections of the immobilisers checking system, starter relay DTC's etc with success only to have the problem return a few weeks later.
    The accident the car was involved in evidently broke one of the clips off the ECU (botton clip out of the two) on the front of the engine. We ended up replacing the whole wiring system thru the engine bay which did not have success. After much reading on the forums, people mention to check earths, possibly cluster and BCM's etc, the fuel sender..... which wasn't really conclusive.
    In the end after trialing a few auto electrictions, mobile mechanics we found a guy who managed to track down the issue for us.
    *** The ECU was infact damaged, obviously the radiator hit it breaking the clip and damaged either the pins, traced or something internal.
    The starter relay was shorting as the ECU earth for it wasn't working.......
    $1650 later........ a new ecu has been fitted, software update and tuned. (included pickup/delivery as it had to be towed)
    If you suffer from a similar problem, a short solution I could suggest is to possibly re-route the earth off the starter relay to the car chassy...... as a short term solution to try. Otherwise as most know u can jump the car with the AC on, a cheaper solution is to put in a Engine Start switch in the dash that shorts the Starter Relay when the AC is on.
    ( I just thought I would share our 6 month drama's solution with you guys ). Alot of people have done fuel sender calibrations, got new bcm's etc......... new clusters....... only not to have it fixed.
    I'll grab the details of the guy who fixed it for us and post it up later if anyone wishes to know.
    PS. Since we only just got the car back, i'll confirm in a few weeks if the cars still going perfectly.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    after doing some testing with getting my car to run without the auto computer (tcm) the same error comes up, so a break in the can system alos causes the same faults, fuel guage error, car wont start etc etc
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    if you disconnect the 5spd auto the car wont start
    - unplug at the gbox connection
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by impulsesv6 View Post
    yeah same thing i was doing, just swapping with another loom, it will start and run for 3 seconds then shut down, and wont crank after that, if you leave the ignition on for a while after, watch the multitude of error codes flash up.
    oh also i forgot to send that e-mail off to ya, ill find my info again and send it off......sorry impulse
    Sep 2008
    Yes the conclusion of ours "Fuel Guage Error and Wont Start Combined" = Faulty ECU. Start goes perfectly everytime now.
    After popping the old ECU open, it's no wonder they fail on the VZ's. Hopefully thew newer alloytech based 6's have a better designed ECU inside.
  1. Fuel Guage Error
    By Bevan08 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2011, 06:35 PM
  2. 'fuel gage error' displayed, ute wont start
    By mickey007 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2010, 05:04 PM
  3. Vz fuel guage error
    By Dan Mcdonald in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-06-2009, 11:32 PM
  4. PLEASE HELP! VR wont start error code 48
    By ecotec_powa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 05:45 PM
  5. VK - LPG - Wont start on fuel..
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-03-2006, 12:01 AM
