hey guys i installed the mace cold air intake enclosure on my vz executive yesterday, i turned the car on and the engine struggles to keep on n keeps reving up n down, i watch the intake meter jump up n down sharply. then the car turns off. also there is a strong petrol smell coming.
WHAT IS THE PROBLEM? how have other people installed the mace CAI and gotten away with it? is there something i need to reset or something.
I have a CAI similar to mace with pod setup..installed it myself a few months ago...no problems till date...what's the intake meter ur talking about???
Ride: VZ SVZ
MODS: Darkest legal window tint
3 inch catback exhaust
Genuine Holden front strut brace
Xenon blue headlamps & number plate lights
CAI with POD setup
NEXT:
upgrade music system
ive installed a vacuum gauge on my car to show the intake. and its jumping up and down when the cars turned on. it never does that with the stock filter.
i heard you can reset the computer? how do you do that
did you disconnect the battery terminals before you installed the cai??
I am not a 100% but try disconnecting the battery terminals and then reconnect after a minute or so...might work...but again not a 100% sure...if its just the computer which might be confused with the more air flow this should work...
Ride: VZ SVZ
CAI with POD setup
NEXT:
ok cheers mate ill do that tonight after work n see how it goes.
reconnect your airflow meter.. I reckon that is your problem.
which ones the airflow meter? theres that thing with two screws that connects onto the air intake manifold with the wire coming out. ive still left that on, basically all ive done is taken the box off n put the new CAI in its place. nothing has changed electronically
hey again guys, just tried disconnecting the battery, left it for two mins to reset the computer and it works fine. errors gone and the car isnt struggling anymore. cheers and thanks, and hope itll b a help to anyone else who gets the same problem
Thats good mate!!!
Ride: VZ SVZ
CAI with POD setup
NEXT:
sorry to say this but the problem is back. allow me to demonstrate.
switch the car on, car turns on but makes a noise silenter than what the engine should sound like. automatically keeps pushing like a rev to keep the car on then eventually turns off.
? WTF
ITS YOUR AIRFLOW METER!!!!!!!!!!!!! Rejack it!
Ive had no issues wen i installed mine.
My 05 VZ CALAIS --> http://s717.photobucket.com/albums/w...view=slideshow
+1 for you've disconnected or otherwise buggered your MAF.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
I had the same problem with my old XH falcon ute. I would just start it then rev the shit out of it and it would be sweet. but that car was 10yrs old at the time. Also when I try to reset the ecu I leave the battery disconected for at least 20 seconds more computer things need like 10 seconds or more to reset propperly even up to 30 seconds.
but does sound like your MAF is crapped it self
sorry just sorted it all out, the airflow meter was the wrong way around and then i reset the ecu again and its all good now
