Results 1 to 16 of 16
Thread: Odd behaviour from air con
    VS Berlina
    Aug 2006
    Angry Odd behaviour from air con
    I have a VZ Berlina with climate control. When the engine is under load eg going up a hill, the airflow will divert from the dash vents to the windscreen demist vents until there is no load on the engine. The effect is loud wind flow noise form the demist vents, no air from dash vents at all until the airflow is again switched back from demist vents.
    This happens no matter what the aircon control settings are at, but seems particularly bad when the climate control is set at about the same as the outside temperature - wind up the climate control temp to a few degrees above ambient and the problem goes away.
    This has only recentrly started happening Anyone any ideas?
    VS Berlina
    Aug 2006
    Just had a search through the forum and found plenty of posts about the same thing so no need to post a reply.
    '98 vt berlina
    Feb 2010
    Quote Originally Posted by raym View Post
    really? can you be a bit more helpful and suggest what phrase to search for to get all the posts regarding this subject? i have to read through 3 pages and tens of post just to get to this one, thanks.
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Would it not be to divert the warmer air away from you while under load (the A/C not cooling 100% while the engine is under load)?
    My old man has a brand spankers Subaru Liberty that shuts down the A/C when stationary - sucks balls in traffic! Apparently to relieve undue stress on the engine, perhaps its the same deal?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    there is a vacuum leak some where
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    evil-matty's Avatar
    evil-matty is offline tyre smoke is normal
    5.7V8 VZ SS M6
    Jan 2009
    Hamilton NZ
    My VZ does the same thing! whenever I start uphill it switches to the window and stops blowing from the front vents. it would be nice if someone here could direct me to some more info as my searches have been fruitless. come on people where is the sense of community and helping each other?
    5.7L VZ
    Jan 2010
    Nthn Beaches, Sydney
    Comon problem, I've fixed a few of them. Your venting system runs off engine vaccum, if that vaccum is lost then everything reverts back to windscreen. There is a small valve usually situated on the passenger side of the fire wall (in the engine bay, not inside the dash), it's half black and half white and is inline with the vaccum source for the dash, this becomes faulty and can cause the issue, it's the most common of them all, however I've had the same issue with loose vaccum ports behind the dash, this small valve *around 1.5-2cm long* is the most common and is cheap as chips from holden.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    I also have this same problem! Bloodying anoying the p**s out of me! So Veriton the best bet is to buy the valve from holden and replace? should fix my problem?
    I dont know if this is related but i put a twin 2.5" exhuast on and i thought that might have been causing loss of preasure in the engine? what do you think?
    5.7L VZ
    Jan 2010
    I doubt it, I've got extractors and twin 2.5" system as well and I don't have the issue. These small valves are the most common component to fail, but not the only ones, about 95% of the time these are the issues.
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    haha, suck. Good old manual air con is the way to go. Climate control too complicated
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Here you go Raym
    Calais climate control on 'AUTO' throws to demister when uphill grade ?? vacuum issue
    Veriton is correct that the primary issue can be the one way valve at the back of the manifold in the engine bay. If it isn't that then be prepared to spend some dollars as the vacuum system can be a bit complicated. Mine needed the dash half pulled out to replace a vacuum actuator near the heater box.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Can someone please put up a pic or two of these valves that usually cause it?
    cheers
    5.7L VZ
    Jan 2010
    Although this is a picture of a VT, this is basically what they look like
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Ok cool i found it. Only thing is how do i check it? i think its ok i blew through it and it worked one way then the other way no air would pass. Means its ok?
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by v8freak55 View Post
    haha, pity the manual air con works the same way
  16. #16
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Yea the manual air con works the same way cause mine is just manual
  1. IAT Sensor strange behaviour
    By ahm09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2009, 09:38 PM
  2. Odd fuel pump behaviour
    By azzfox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 09:22 PM
  3. Error 41 but not usual CAS Behaviour
    By Drumstick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2008, 10:47 PM
  4. VP V6 Strange Behaviour
    Last Post: 18-06-2008, 01:15 AM
  5. Very strange behaviour from my VT
    By Stretcher Bearer in forum Electrical Wiring / Questions
    Last Post: 13-05-2006, 01:15 AM
Tags for this Thread
