Results 1 to 18 of 18
Thread: Coolant change
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default Coolant change
    Im wanting to change the coolant in my car, I have bought the 5 litres of coolant from Holden, now im just trying to work out where the drain plug is?
    Secondly, when I fill the coolant up do I put the 5 litres in then the rest water?
    And does the system then need to be bled?
    Better still if anyone has the official manual could they upload that section of the book into here?
    Thanks!
    vz berlina v6
    Aug 2007
    vz berlina v6
    Aug 2007
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    thanks for that vzberlinav6. Any chance you could upload the spark plug procedures? Thanks!
    VZ SV6 && 180sx
    Mar 2008
    vz berlina v6
    Aug 2007
    heres how to change the spark plugs
    Attached Thumbnails Attached Thumbnails Coolant change-spark-plug-replacement-65.jpg   Coolant change-spark-plug-replacement-66.jpg   Coolant change-spark-plug-replacement-67.jpg   Coolant change-spark-plug-replacement-81.jpg   Coolant change-spark-plug-replacement-82.jpg   Coolant change-spark-plug-replacement-83.jpg   Coolant change-spark-plug-replacement-84.jpg
    Coolant change-spark-plug-replacement-85.jpg   Coolant change-spark-plug-replacement-86.jpg
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    When changing cooalnt make sure of the folowing: (1) ensure that coolant to be used complies with Holden's specifications (to do otherwise may result in eventual damage to your engine block etc). (2) make sure that you use only Demineralised water or Distilled water. Tap water may have too many additivies and minerals which could be destructive to your engine components.
    Most cooalnts will have specific instructions as to what ratio to mix it. For example it may be 5 litres of coolant to 5 litres of water. You have to check your Owners Handbook, it will give you the correct quantity for your cooling system.
    I always drain my cooling system as best I can then flush with rainwater to a final fill with just rainwater. Run the engine for 15 - 20 minutes, drain water and once engine is cool enough add coolant then the required amount of water. If you go to a Radiator Specialist, they have a very neat piece of equipment that they hook up to your cooling system and it purges the old coolant etc.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Can anybody tell me why the Holden
    service specifically mentions not to
    use anti-seize when changing the
    plugs?
    Affect torquing or O2 sensors?
    No mention of block drain plugs in coolant
    replacement? Superfluous?
    I'm not afraid.
    V6 VT Commodore
    Aug 2009
    Tamworth, NSW
    i wanna know the same but for a V6 VT...where or how do u drain the coolant?
    Exidor's Avatar
    May 2008
    Earth. For now....
    Quote Originally Posted by MY-42-VT View Post
    Try VT to VX forum.
    I'm not afraid.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    rodbol, a small smear on the threads wont affect it, nor will it affect the tension
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Exidor's Avatar
    May 2008
    Earth. For now....
    Quote Originally Posted by andyman View Post
    Thanks. I was a bit worried because I
    used O2 safe anti-seize.
    I'm not afraid.
    vz ss 6ltr
    Sep 2009
    your best bet is to take the thermostat out flush the motor then refill as i no i am a radiator man
    VZ SV6 && 180sx
    Mar 2008
    Is this what holden uses?
    I need to top mine up, so want to use the exact same.
    WTB: VZ Chasers
  15. #15
    vz acclaim
    Oct 2009
    hi i am new to vz commodore and was wondering if i remove the radiator cap when cold should i see the coolant as the recovery tank is showing full but i don't see any coolant siting or flowing at the cap
    any help will put my mind at rest lol
    dave
    ps it doesn't over heat at all so was just curious
  16. #16
    vzv6
    Aug 2010
    qld
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by vz ss 6ltr View Post
    Tried taking the thermostat out on an alloytec?
    Silver Certified.
  18. #18
    AZY
    AZY is offline
    VZ svz
    May 2010
    Default VZ service manual
    Quote Originally Posted by vzberlinav6 View Post
    hey man where did u get the service manual i been looking around and couldnt find one or order one?
    thanks
  1. SS coolant change
    By Holden V8 SS Ute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2009, 03:21 AM
  2. Coolant change
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-06-2008, 06:06 PM
  3. HELP! how do i change the coolant!?
    By judoman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2006, 06:34 PM
  4. Coolant Change
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:39 AM
  5. Coolant Change
    By DJ Majah in forum General
    Last Post: 29-04-2004, 11:22 PM
