Results 1 to 5 of 5
Thread: Coolant smell
    VZ Executive wagon
    Mar 2009
    at my house
    Default Coolant smell
    Hi guys,
    About 8 months ago I bought an 04 VZ wagon with 95 thousand'ks. While going over it at home I found only water in the radiator so I changed that for coolant I got from Holden. Pretty much since then I have been able to smell coolant when the motor is warm. I don't think it is using any of the coolant and there is no signs it is getting into the oil or anything. The motor does have a slight wining noise kind of like driving with the A/C on but its not. I was thinking maybe the water pump is on its way out and some coolant is getting on top of the hot motor hence the smell. But I'm not even sure where the water pump is on a Commodore because its my first (I have always had Ford's). I didn't think Commodores had head or gasket problems or at least I'm hoping not. Any help or advice would be much appreciated. Thanks.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Suggest you go to a radiator/cooling specialist and have your cooling system pressure tested. The only way (for sure) to find if you have any leaks/problems.
    vt ss commodore
    Sep 2009
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    more than likely the casting plug on the water pump is weeping, or the heater hoses clamps are loose
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Executive wagon
    Mar 2009
    at my house
    Ok, thanks for the replies guy's. It gives me somewhere to start looking.
  1. Smell coolant through air vents?
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 10:58 PM
  2. can smell oil in the coolant resivoir
    By mundine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 07:08 PM
  3. Coolant smell
    By ringfeder3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2008, 12:40 AM
  4. coolant smell??
    By clarkey3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 10:57 AM
  5. coolant smell
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2004, 12:48 PM
