Results 1 to 5 of 5
Thread: Computer errors
    VZ Crewman 3.6 1995
    Oct 2009
    Default Computer errors
    I have a 95 crewman 3.6l & its just turned over 50,000km's. Ive recently encountered this problem with a couple computer errors. The initial error happens when I go to start the car and a low fuel sensoer error appears disabling the car. I overcame this problem by removing the starter relay. Then when I went to start the car again a power transmission error occurs. I can still start and drive the car. To reset that error I removed the battery power lead. All ok, drives no problem for a period of time. It seems to happen when I dont turn the key over fully and do like a quick half turn. I have taken it to the Holden dealer to plug the computer in and the Mech. said there were no probs just a glitch and he did a reset. But since then its happened 3 more times.
    Has anyone encountered such a problem?
    VZ LX6 Adventra
    Aug 2009
    howdy, cant say ive had any problems like that before, but seems a bit weird i'd maybe try another dealer and get their opinion on it. Sorry can't really help but good luck with it
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    i doubt many people would've had this prob cos holden didn't make a crewman in 1995
    Chev badges are an instant fail
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    ecu or bcm faulty (educated guess) ......... also check starter earth.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    if fuel guage error occurs and check powertrain etc, id be checking the PIM powertrain interface module,
    this links all modules together in the can-bus system, if this breaks down. the can bus system wont communicate hence a no start situation
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. Code errors
    By VRoooom! in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 12:51 PM
  2. VT V6 errors need help
    By dammit_billy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 01:53 PM
  3. CAS Errors....again
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2008, 06:13 PM
  4. vs errors
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2007, 06:59 PM
  5. Errors #81 & #83
    By Sylvester65 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2007, 08:14 PM
