Hi guys,
Can anyone help me. Im on holidays in the Hunter Valley atm, just got back from dinner parked the car at the hotel and got out locked the car. All the lights go off and everything is as normal except the radio is still on and wont turn off??? I dont have the pin # with me so i cant disconnect the battery. what is wrong and is there any solution cos it will be flat in the morning i assume?
Any help appreciated
remove the fuse
beat me too it
that happened to my vt a few days ago, i just removed the fuse, put it back in and all is good, swithes off agian with the key
willl it require the radio pin if i do so??? cos i cant bear to drive 3 hours with no music
VZ-Rob
98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
VZ-Rob, the radio was on then ignition was turned off and door opened and shut, car locked and the radio was still on, if you turned it off it'd remain illuminated instead.
Anyway, turned out that the fuse for my bluetooth kit had blown preventing it from turning the kit off and making the radio believe it was still connected, thus not turning off
