Results 1 to 8 of 8
Thread: L98 conversion on an Exec
    Jun 2005
    Default L98 conversion on an Exec
    I got a friend that is buying a L98 for his VZ exec V6. I'm not sure what comes with it, but i think it is engine, box, loom, ecu, k frame, and any other mounts. will he need anything else in order to do the conversion, such as dash clusters, sensors, or any other electronics parts?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Jun 2005
    wait sorry, i meant LS2. its out of a vz maloo. assuming theres not much difference anyway?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you will need, engine bay loom and dash loom, + all other mounting ancillaries
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Jun 2005
    any idea if the dash cluster itself is needed? also, about the tailshaft. since its coming out of a v8 manual ute, and going into a v6 sedan with an auto, what needs to be changed? will only the front half of the tailshaft need to be changed to suit the sedan with the manual in it?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    being a 4sp v6 sedan, you will need a new tailshaft, you cant split the 4sp tailshaft as they are a press fit unit,
    so yes you will need the tailshaft to suit the v8 gearbox you have
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by stocky View Post
    the cluster i would assume that holdens or someone with a tech 2 could sort that out with an update
    Chev badges are an instant fail
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    oh yeah, dash cluster will be fine, just a reprogram needed
LinkBacks (?)
  1. 12-10-2009, 02:31 PM
  1. Lpg Conversion..is it worth?? VY EXEC
    By matt 7650 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-12-2010, 11:24 PM
  2. VZ exec rear power windows conversion
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-04-2009, 12:37 AM
  3. vl exec to belina dash conversion 2nd question
    By Milkman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2006, 08:57 PM
  4. vl exec to belina dash conversion
    Last Post: 28-03-2006, 10:32 PM
  5. VP exec to calais conversion
    By PANDO in forum General
    Last Post: 10-02-2006, 02:24 PM
