Results 1 to 7 of 7
Thread: Powertrain Issue with Cruise Control
    06 VZ SV6
    Mar 2008
    Default Powertrain Issue with Cruise Control
    Hey all, been reading up on the whole Powertrain Issue, and I have a feeling my problem has something to do with me getting a cat back exhaust. The thing is, it ran fine for a 7 hour trip (pretty much the whole way on cruise control) and then with an hour and a half to go to my destination it went in to limp mode. I had to pull off to the side of the road and let it sit for a while. I then continued on with no problems although i did not put it in to cruise control. i was away for 6 days and drove the car minimally with the warning being up for the first 4 days or so and then disappearing. so i started my drive home thinking it might be alright to put cruise control on again, within minutes it went in to limp mode. i let it sit again for a few minutes, and then continued on with the warning on the whole way, and did not use cruise control. About half an hour after i got home, the fault had gone again, and the car has been fine for 10 days now, although havent tried cruise control yet.
    Anyways, thats the story, would i be better off replacing my exhaust back to stock, or getting it scanned by mechanic?
    Also, I have a mace CAI, and recently theres been quite a smell of fuel in the cabin, i only notice it occasionally but its definately there, any ideas?
    Apologies for the long post
    Cheers,
    Daz
    PHOEN1X - 06 VZ SV6
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Probably nothing to do with using the Cruise Control (couldn't really imagine how it could). Most likely more to do with modifications or even battery condition. Take it to a workshop with a suitable scan tool to accurately identify source.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Not sure personally what this would be. At a guess, I'd firstly change your CAI back to the stock airbox.
    Normally cruise control etc will play up for example if u got exhaust issues or you've just left the PCV hose off the intake pipe.
    The exhaust could be a O2 sensor gone, causing some fueling issue....... (same as how the cats heat up when u first turn on the car) ........
    But really, get it scanned......... until u know what error code is lodging your blindly guessing and so is my advice.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Mar 2008
    I know it might be a silly question but have you installed the MAF on the correct way when fitting the CAI kit?
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    06 VZ SV6
    Mar 2008
    Doesnt it only go one way? And wouldnt there have been earlier issues if it wasnt? CAI has been on for 6 weeks, and this happened 2 weeks ago just after my exhaust went on. And its driven fine ever since, just havent put cruise control on. Ill have to have a check when I get home
    PHOEN1X - 06 VZ SV6
    Mar 2008
    Quote Originally Posted by Phoen1x View Post
    "Doesnt it only go one way?"
    It can only work one way but you can install it both ways.
    "And wouldnt there have been earlier issues if it wasnt? CAI has been on for 6 weeks, and this happened 2 weeks ago just after my exhaust went on. And its driven fine ever since, just havent put cruise control on."
    It should have shown up as soon as you installed the CAI, but when it comes to cars you just can't be too sure
    "Ill have to have a check when I get home"
    Keep us all posted
    Steve
LinkBacks (?)
  1. 05-01-2010, 01:46 PM
  1. VX S2 HBD Lumina Cruise Control Turning Off Issue
    By $inisterinc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2011, 08:48 PM
  2. Cruise control issue..
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 09:54 PM
  3. Cruise control issue
    By ST4s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2008, 08:08 PM
  4. VS cruise control installation issue
    By vsiicalais in forum Electrical Wiring / Questions
    Last Post: 07-08-2008, 10:38 AM
  5. VR V8 Statesman - Cruise Control Issue.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2007, 07:27 PM
