Results 1 to 5 of 5
Thread: Removal of Surrounding Frame around steoro / air con.
    2005 VZ Sedan Barbados Mica Blue
    Mar 2008
    Default Removal of Surrounding Frame around steoro / air con.
    Hi, i started to remove the surrounding panel around the stereo and Air controls that extends up to the dashboard.
    I removed the top panel exposing 4 screws at the top. There were metal clips running down the sides, but there was resistance from the bottom of each side so i backed off.
    Are there screws at the bottom as well?; do i need to remove the isde panel to get to them?
    or are there clips at teh bottom too?
    06 VZ SV6
    Mar 2008
    You have to remove the bottom section first (between centre glovebox and the spot u are talking about)
    Lift the lid up of the centre glovebox, and get a flathead screwdriver down the hole in the front of it and pop the centre console up. work ur way all the way up the centre console, i think theres about 3 clips on each side.
    have no photos at the moment but ask if you dont get what ive said.
    Daz
    PHOEN1X - 06 VZ SV6
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Mar 2008
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    sometimes the forum search doesnt work 100%, Ive found (as have many) a google search will usually bring you back to JC anyway.
  1. Replies: 13
    Last Post: 20-05-2008, 12:53 AM
  2. Removing Dash Vent / Surrounding
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 10:03 AM
  3. Replies: 40
    Last Post: 17-05-2006, 06:03 PM
  4. How do i get the door handles out and the surrounding ? (inside)
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:07 PM
