Im looking at purchasing a 2006 VZ Executive sedan. Are there ANY problems with this model that I need to know about or keep an eye out for?? Thankx
I got a 06 VZ Exec, not an issue to date (had it bout 1 1/2 years)........ maintence yes, but nothing really. I think u just depends on the car really.......... some will have faults, some wont.
poweredbycng well ur wrong, the 06 VZ Execs have 4 if they are a May06 model (euro 3)
2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
My 04 VZ V6 has 115000 klms without an O2 issue.
But has the Tchain cold start rattle (tensioner?) common
to some examples.
I'm not afraid.
Yep mine has the timing chain rattle. Just make sure you have not got excessive diff lash back and also make sure suspension bushes are in good condition (no creaks from the suspension and it should stay straight when you brake hard.
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
* Ignition coils have been known to fail around 120k-150k
* Oxy Sensors as previously mentioned around 100k
* Oil pressure senders have also been known to fail on vehicles with a lot of Ks
* Fuel gauge problems are also common
* Also check things like power steering pump, water pump, pulleys. If you can spin them by hand and there is a bit of play in them they may be on the way out.
mines done 150,000KM
had to replace the thermostat & water pump.
although this may have had something to do with me using John Deere tractor coolant (for cast iron engine blocks) on an alloy engine, the alloytec. lesson here is, dont do what i did, as it costs you shite loads in parts and more specifically labour (thermostat is in THE most inaccessible place ever on an alloytec)
but apart from that, no issues with oxy sensors or anything else.
"And i gave that man directions, even though i didn't even know the way; because thats the kinda guy i am today"
Like any car. If they have not been correctly maintained and driven 'like they're stolen', then it would be reasonable to expect problems - regardless of the mileage covered. If you are unsure, get your local AA (Automobile Assocition) to perform a check of it.
not really important but my O2 sensors (well, front left) went at 68,000 so i just replaced them both
I've had mine since 60,000km and it's just about to tick over 100,000km. (30 k's to go!)
I haven't had any problems. It does have a noisy diff, my mechanic reckons that it's fine and alot of VZ's have this.
The stock rims are shithouse, get some that you can put wider tyres on and grip will be heaps better. Used to get wheel spin all the time in the wet, and I was being pretty careful with the throttle. My tyres may have also been crap, but alloys look better than stockies anyway. (This isn't really a huge problem but can be annoying when taking off from a stop up a hill in the wet.)
Thanks Everyone!!
Just don't go manual ^_^
Here is a website for VZ faults:
Faults - VZ
But personally I love the VZ.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
