Results 1 to 13 of 13
Thread: VZ ss exhaust on VZ sv6? help
    VZ SV6
    Oct 2009
    Question VZ ss exhaust on VZ sv6? help
    hi guys,
    i'm new to this & just wondring if ya can help me out with some advice on an exhaust system.. i was leaning towards a VY-VZ ss exhaust system because of the dual tips and because apparently they don't make the car much louder... mrs will have a cry if its too loud!
    thanks
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Changing the exhaust tip won't make any difference to the performance or noise from exhaust. Suggest you go to an exhaust specialist for a definitive answer.
    VZ SV6
    Oct 2009
    Wink
    thanks for your advice benboy,
    do you know if the exhaust tip is the only difference between the sv6 & ss systems?
    az_sv6's Avatar
    az_sv6 is offline coudnt aford a v8
    vz sv6
    Sep 2009
    western sydney
    VZ SV6 && 180sx
    Mar 2008
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    okay when you use an LS1 exhaust its dual pipe down to the end, similar to that pic whereas the current V6 exhaust merges in before the last muffler from memory. I dont know if you can use the 6 litre exhaust, Ive only ever seen the 5.7 LS1 exhausts fitted.
    Overall on full open throttle it growls a bit, say off a set of lights, but after that it goes quiet.
    At our skidpan day last week we had 2 cars with this modification and when thrashing them on the pan they sounded awesome inside the car, but quiet as for the spectators.
    Overall Im happy with it, and as far as I know you cantget done by EPA or anything for having it as it is still a standard exhaust, with HOLDEN imprinted on it!
    You will need to make and weld a new bracket to the chassis of the car though to hang the new second muffler from
    VZ alloytec Calais
    Oct 2009
    Port Macquarie
    Hi DaneSV6 ,I picked a genuine SS exhaust up off ebay for $50. It is as the guys have said a twin 2.25 inch system right through to the tips. I fitted it to my VZ calais , it fitted up perfectly as all the brackets are already there, all you need is two gaskets for the joints after the cats. It does sound a bit louder , and does growl abit when you give it to it , but it does not sound raspy or farty. As far as performance goes it feels more responsive down low and definately has a bit more go up high. I also did the two hole mod and the economy seems to have improved also . For $50 I am really happy with it and i think you would be too.
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    i've got a 5.7L stock system on my wagon and i love it, idle is quiet as stock, but if you floor it right through the rev range from stand still it sound sweet!
    VZ SENATOR
    Mar 2009
    Anyone got any videos of the V8 exhaust system on an alloytech? Id love to hear what it sounds like
    Torquative's Avatar
    Jun 2005
    sorry forgot, yeh on Calais and SV6 the second brackets there as the 190Kw varients have the same exhaust, only the SS is bigger.
    On 175kw varients like executive or my acclaim you need to make a second bracket as ours is single pipe most way through.
    VZ SV6
    Oct 2009
    Thanks for all your help guys. A great help!
    I'm getting an ss system off a 5.7 litre vy-vz this w/e cant wait!!!
    Yeh iv'e done the 2 hole mod + k&n filter and feels much better. Changed the sound too.
    Deeper, smoother sound.
    Anyways i'll keep yas up to date when i get it!
    THANKS
    danesv6
    VZ SENATOR
    Mar 2009
    If you are going for sound it sounds like a great mod, but just something to keep in mind...
    Quote Originally Posted by Peanuts Inc. View Post
    the new alloytechs have a tuned exhaust and doesnt really need to be touched because you WILL lose power somewhere along the rev range......holden should of just made it a bit louder out of the factory and it owuld of been sweet
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As mentioned, the SV6 already has the brackets required to fit the twin system.
    VT-VZ V8 and V6 twin cat models that have the flanges in the same position as the V8's, the exhausts are all interchangeable.
    Visit my Facebook page
  1. [SA] Swap VY custom exhaust for standard vy exhaust
    By SAV_117 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2009, 09:20 PM
  2. Exhaust / Catalytic flanges, Exhaust swapping
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 11:02 AM
  3. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  4. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
