gday all.I need help with diagnosing an ignition lock problem.Its like im using the wrong key.It just wont budge.is there an electrical contact that allows the lock barrel to turn?both keys wont work.something snapped inside?any advice before im at the mechanics mercy?![]()
Had this problem once aswell. Apparently its really common, have to get the ignition barrel replaced. But for now try spraying some CRC in it, poke your finger through the whole in the steering column and wiggle it around.
Will most likely have to get it replaced though, think its about $200 from holden supplied and fitted.
I might sound stupid... but did you wiggle the steering wheel before trying to turn the key?
that sounds stupid.i felt like breaking the steering lock
thanks brods.
