Results 1 to 18 of 18
Thread: VZ LSD Diff
    VZ Berlina
    Oct 2009
    Default VZ LSD Diff
    i wanna get a LSD diff for my vz wat would be a good choice for that
    VYII S
    Jun 2008
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    If you can afford it get a kazz centre. The standard Holden LSD's cluck and are weak as piss.
    Exidor's Avatar
    Exidor is offline I come in peace.
    Used Martian spacecraft
    May 2008
    Earth. For now....
    Quote Originally Posted by Braba101 View Post
    You mean ratio?
    I'm not afraid.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    3.08:1, 3.46:1 are the best for a VZ 6. Any higher & u start to loose top end speed.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    vtcommodo3800's Avatar
    vtcommodo3800 is offline Got me a v8!
    2007 VZ SS Thunder
    Oct 2005
    VZ SV6 05
    Sep 2008
    Quote Originally Posted by vtcommodo3800 View Post
    i will be selling the diff out of my vz ss thunder soon 3.46.1 lsd
    How much you after?
    2007 VZ SS Thunder
    Oct 2005
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    3.46 lsd is ok, on the execs (4 speed auto).... depending on your stock tune, u may have to get ur WOT gear changes adjusted as it doesn't run as high as a 3.08 in terms of km's per gear.
    eg. my 3.08 would run to like 71km in 1st top end....... 3.46 will run to like 66 at absolute most.... when i changed my diff my 1st/2nd gear refused to change under WOT because the gear change was set higher then the diff could run to.
    changing the diff means you have less km's per gear in the rev range........ but it's a bit quicker so....
    dunno myself....... 3.08 lsd is ok, 3.46 lsd a tad more work maybe. ( i got a 3.46 reconditioned one, fitted it myself)
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ Executive BT-1
    Nov 2008
    ive got the 3.08 in my exec and i find it ok...bit sluggy but HEAPS comfortable to drive with
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    ^^^considering thats the std ratio in VZ exec!
    The Blue One
    Quoted for truth
    VZ Executive BT-1
    Nov 2008
    yes, yes it is....but an opinion has been asked for so i gave him mine...
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Yeah tats cool mate but 3.08's aint lsd. 3.46 & higher are.
    The Blue One
    Quoted for truth
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Quote Originally Posted by PaulSV6 View Post
    you can get a 3.08 lsd. the vz police packs have em. have been contemplating this for ages...
  15. #15
    Sep 2008
    yeh my dad has a 05 police pack exec..... the 3.08 lsd's feel slower then the 3.08 single spinners .....
  16. #16
    -scyth-'s Avatar
    VZ Wagon 05
    Nov 2008
  17. #17
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by -scyth- View Post
    I thought that the VZ pol packs had 3.46 lsd! Whereva i saw it i most likely red it wrong.
    The Blue One
    Quoted for truth
  18. #18
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    hey paul nothing wrong with the 3.08 single either, talk to hayden about the difference my car had on the skidpan compared to most of the LSD's.
    I wouldnt mind changing the gears for a bit more oomph but thats about it
  1. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  2. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  3. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  4. VT-VZ IRS LS1 Diff will it bolt up to V6 IRS Diff cradle?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 09:51 AM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
