Results 1 to 5 of 5
Thread: VZ SS 4sp auto wont upshift
    vz ss
    Dec 2008
    Default VZ SS 4sp auto wont upshift
    Driving home from work turned off the highway went take off smooth change up into 2nd then stuck in gear. was running smooth up till today.
    Would the fluid level be a factor..
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Yes, most likely. How long since you checked it? Fluid is cheap, repairing/replacing auto trans. VERY expensive.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Hopefully its just low fluid but unlikely unless you have a leak somewhere or was never properly filled.
    When the auto went on my old VS super6 it did exactly the same, only had 1st & 2nd gears, the centre part of some shell in the gear box had torn apart.
    Apparently this part was modified and strengthened post VS (VT onwards) and also in my rebuild.
    But the short story was that it was a full rebuild back in 2002 with only 80K klms on a stock engine.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    I would be checking ur fluid level, before driving anywhere!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    vz ss
    Dec 2008
    Fluid level was fine, the hooked up to the scan tool no faults found. looks like the pans coming off and solenoid problems.
  1. Engine cutting out on gear upshift (auto)
    By red131 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-09-2006, 11:43 AM
  2. Tranmission upshift problem
    By Clinster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2006, 02:27 PM
  3. RB30 auto box wont kick down at all.
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2005, 07:19 PM
  4. auto trans starts in second gear,no upshift to fourth
    By driver in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-11-2005, 07:04 AM
  5. auto trans stuck in first no upshift
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2005, 03:52 PM
