Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: Alloytec 6 speed gear stick
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Alloytec 6 speed gear stick
    Hey i was just wondering if anyone has any diagrams on how the gearstick seperates from the box or anything similiar to that.
    Maybe out of a workshop manual or something.. IF you do could you please let me know!
    Life starts at 200km/h
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    theres 3 clips that hold the linkages to the top of the box, then the 4 nuts that hold mounting plate to the body of the car
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    I'm talking more about the actual gear stick itself, how to removing the top (Thicker) piece from the other, looking to modify it
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ 3.6
    Feb 2009
    North of Adelaide
    Just a question on a VZ manual thread
    if im driving along the highway at 80kph in 6th gear and i plant my foot, obviously the revs take a while to build up from 1500rpm, but the worst sound occurs, almost like a groaning sound. it goes away once the revs reach 3000-3500rpm.
    it only really happens when i plant the foot in 5th or 6th while the engine is at low revs.
    its hard to say where its coming from, but it seems to be coming from the motor not the gearbox.
    What do other VZ manual drivers think? i wouldnt think auto drivers would have ever experienced this as the trans would just change back a gear...
    "And i gave that man directions, even though i didn't even know the way; because thats the kinda guy i am today "
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by impulsive View Post
    hey andyman does this remove the cover or the stick?
    It removes both, as the gear knob is part of the boot cover & cant be seperated.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    It isn't, if you take the button out their is a screw behind it and then the front plate lifts off.
    Thats how I changed my VZ auto stick from plastic to chrome.?
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by mainpath View Post
    Mate, where talking about a manual gear stick here, not auto! hence the thread title.
    The Blue One
    Quoted for truth
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    The gear stick has two parts atleast i think it does, the Thick bit up top and a smaller narrow linkage, i wanna seperate the thick form the thin
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    you can break the sealant on the the large knob by turning it real hard, i believe its only a rubber moulded thing, you can break it off,
    i sense a shorter shifter idea comming about from this........
    you can remove the knob off the stick by jamming 2 small screwdrivers in under the blue ring tab at the base of the knob, lever them out, while holding them, reef the gearknob off the stick,
    if you then want to make a different knob, pull the boot back over the knob, cut the cable tie holding tit on, then remove the boot from the knob
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    yeah your spot on.. i can remove the knob from the car, what i dont want is sparks and shit flying around my car from cutting and remoulding.. is there a way to remove the actual top part of the stick,the bit the knob sits on so it can be modified?
    Impulsesv6 do you still have the photo i sent you of what im talking about?
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
  15. #15
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by juzo View Post
    The stick the knob sits on is screwed to the side of the shaft. Just undo the screws and the stick is free.
    v8 is different juz,
    impulsive, if you get the stick and mount the fat bit in a vice, then twist the rest of the gear selector off the top part of the selector, im pretty sure you can do it like that,
    as the top bit is rubber impregnated when made
  16. #16
    Nov 2005
    Warrnambool
  17. #17
    mdmatt is offline mdmatt
    2005 LS1 Auto VZ SSZ 328.6rwhp
    Aug 2009
  18. #18
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by mdmatt View Post
    VZ 6spd manual - WORST GEARBOX EVER.
    ****ing hate it, piece of shit.
    works good for me
  19. #19
    Aug 2009
    they are notchy, clunky, half the time don't go into gear..
    they're a piece of shit
  20. #20
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    is your clutch fluid bled correctly, they have a stupid bleeding system and if there is air in there it will create those problem as the clutch wont be fully disengaged
  21. #21
    Aug 2009
    Yeah everything's fine, a family friend works at a local holden and has said the VZ manual box was just that.. it was crap, nothing good about it.. i do agree though
  22. #22
    Nov 2005
    Warrnambool
    I've never had any issues with mine i must say. Do you have a shifter? Mine felt a bit notchy and was hard to select but when i put in my rip it improved it 100%
  23. #23
    Aug 2009
  24. #24
    Nov 2005
    Warrnambool
  25. #25
    Aug 2009
    cheers for that =]
  1. Thread size for 5 speed gear stick
    By Leroy14 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-04-2009, 06:47 PM
  2. Gear stick vibration vu 5.7 ute
    By afterburn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2008, 04:49 PM
  3. Gear stick
    By REVDUP in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2006, 08:11 PM
  4. gear stick
    By MELBOURNE DISASTER in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-01-2006, 09:13 PM
  5. Anyone Know Where To Get A New Gear Stick?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2004, 12:25 PM
