Just need your thoughts..
Driving around town accelerating sometimes the car loses power, stops accelerating basically, the exhaust gurgles a bit then it gains acceleration normally, it also feels like the car has lost a fair bit of power aswell
My initial thoughts were fuel, plugs, or even a miss..
Life starts at 200km/h
going to replace the plugs on the weekend, anything else i should do while the manifold is off?
Could be a bad batch of fuel youve picked up!
When was the last time it was serviced?
The Blue One
it sounds very similar to the problem I was having with my coils.... see if replacing the plugs fixes it, if not they might be something to check.
yeah, well bought some new plugs today, just finished replacing them, went for a test drive, no missing.. car is running good, hopefully it stays that way
If not, check fuel filter......... only thoughts.
2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
that was th next step! Fortunately the car is still running awesome
im having the same problem with my ute.
i have asked 2 mechanics and they dont have an answer for me it is dangerous as the engine just cuts power and idles it usually happens when im overtaking.
i have to turn the engine off and start it again and the problem goes but returns a little later.
i get it serviced about every 2 months the problem just keeps appearing.
some help or ideas would be much appreciated
There was a batch of dodgy coil packs on some of the earlier VZ's. Coils manufactured "04-05-08", "04-05-09", or "04-05-10" (8th - 10th May 2004) are known to fail prematurely and should be replaced. The manufacture date is printed on the coil.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
