Results 1 to 13 of 13
Thread: Lowering my wagon
    VZ Berlina
    Oct 2009
    Melbourne, VIC
    Default Lowering my wagon
    Hi everyone,
    Have been cruising the forums for a few months now and have finally had an excuse to post!
    I'm just about to get my VZ wagon and am looking to lower it. Right now it is on stocks (as it is ex-corporate).
    However, I'll be loading up the back and sometimes towing a trailer and I'm worried that if I lower it too much up the back throwing the weight on will kill me, but I don't really want to lower the front and leave the back. I've thought about air bags, but that seems too costly.
    Any ideas?
    Thanks,
    Zender
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    My old VZ wagon has Super Lows and was rubbing the tyres, played around with the guards a little to sort that out and it's all good now.
    Its had about 300kg in the back (IKEA shopping spree) and it was alright, I wouldnt be putting much else in it though, I wouldnt be towing a trailer with too much weight either.
    VZ Berlina
    Oct 2009
    Melbourne, VIC
    Will those airbags also be compatible with lowered springs, or only with stock?
    The ride height on that VZ is slick, I'm wondering if adding airbags to that would let me tow a boat for instance? (I don't actually have one, but like to keep the options open)
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    bah i had my car as low as that, i towed a trailer full of camping gear, food, accessories etc, not exactly light, then had more gear in the back of mine, never had a problem, didnt even sag really, ive got the airbag shocks in mine, but i havnt used them, even when towing a 2t GCM horse float,
    i find in interesting you say it scraped, i had mine sitting on bump stop one night car full of people, never once had it scrape
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Hey kikki, what size are your rims? & are the fronts on SL's? thats the height i want for my wags... cheers
    Quote Originally Posted by Kikki View Post
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    Kikki's Avatar
    Aug 2007
    Eaton, WA
    2005 Vz Calais 190
    Aug 2008
    Sydney!!
    VT Wagon
    Aug 2010
    Kalgoorlie
    my wagon has ssl's and scrapes up curbs with no weight in it
    but you could get rubbers made up to put in your springs, similar to 4wd lifting blocks. basically just a rubber donut.
    they aren't off the shelve items though. i got a rubber lining company to make me some up for a small fee.
    pretty simple to put them in and out...and you can have the best of both worlds. put them in for towing etc, and take them out for cruising.
    Redline SSV
    Jun 2008
    Just get a heavy duty set of springs for the back... I had KHRL-46SLHDs in the rear and it barely changed with weight in the car... They're pretty thick springs... And it should get a look like the VZ wagon posted above... Don't get non-heavy duty, they sag heaps with weight... My car has KHRL-46SLs in the rear, and with 3 people in the back it goes from arch tucking a little tyre to tucking rim...
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    You need Polyair Airbags for the rear springs. The appropriate part number is:
    #12493
    To suit: COMMODORE VR, VS, VT, VX, VZ WITH I.R.S. (INCL. STATESMAN & FE2)
    You can read all about them here Polyair Springs air bag suspension lift kits
  1. VR - VS Wagon lowering
    By gts004 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 10:02 PM
  2. Lowering the Wagon....
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2009, 10:56 AM
  3. lowering wagon.
    By spxdsn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2007, 04:28 PM
  4. lowering a vt wagon
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2006, 05:31 PM
  5. Lowering my VP Wagon
    By ChrisVPCommodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2005, 10:11 PM
