seatbely warning chime is on all the time and red light flashing even with the seat belt in obviously the beeping gets louder over 20kms. Any ideas?
1x visit to holden
was intending on doing that just thought someone might have a trick up their sleeve.thanks anyway.
Is it beeping, and then your dash screen is reading 'Driver Seatbelt' or something like that, or just beeping?
If it's just beeping, it could be the passenger's seat, you may have something on the seat, which the car is reading as an occupant due to the weight.
Check the Fuse!
The Blue One
I'm reasonably sure that the warning is only connected to the driver's seatbelt. Check the wiring under the seat. The seatbelt warning wires are very thin, one is black with a white trace and the other is brown with a black trace (I think).
There are connectors under the seat. It's possible the wiring has become dislodged if something has been pushed under the seat.
will have a look at that thanks.
I will get back to you on that one. Took car in to local agent here and mechanics recon it could be the pretensioner but this doesnt make sense to me because once the pretension goes off you cant use the seatbelt well thats what i think anyway.
