Anyone know of or have had a VCM suite tune in Melbourne? most places won't touch the V6. thanks.
I had mine done at a place called 'Autotechnique' in Ferntree Gully.
I got quite a bit of extra torque out of mine, cost me just over $1000, for me I reckon the cost justifies the value provided.
P.S. If you do go there, make sure they program the computer to not bring up the 'Powertrain Fault' message. I had driven bout 8km after the tune before it came up, took it back and they happily reprogrammed it.
Good luck, upload the dyno if you do get it done.
Thanks man I'll look into it![]()
also, (and i'm actually just near vcm in knoxfield). There's a joint called ICES in rowville, they quoted me $750 for essentially the same thing.
Whether or not they get the same results, i'll let you know soon enough![]()
i had mine done at Electronic Automotive in Epping.
Let me warn you tho, the tuning on vz/ve v6's is VERY limited.
Don't expect too much!
Drive it
Like ya stole it!
You guys are so lucky, cheapest tune up north (that I would actually trust) is $1500..
WTB: VZ Chasers
Yeah kW wise didn't get much (from memory 117 to 132), but my torque increased by nearly 50nM, to 382, I think it was (should double check the exact figures).
You can feel the torque improvement, especially low down, like in 6th, the car can pull from 50 to 80 a lot better than previously.
I'm getting 9-9.5L combined, which I think is the biggest gain in the whole procedure (got down to 7.4 on the trip to Robe)
I would be very interested tp see what improvements a tune can do on the SIDI Engines in 12 months time.
sweet im thinking about getting it done to my vz berlina!
once every1 has done it or if u hav the dyno run post it soo we can c where iz better value for moneyy thanxx guys
