Results 1 to 7 of 7
Thread: Alloytec Oxy sensor change - HELP!
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Default Alloytec Oxy sensor change - HELP!
    Does anyone have any hints how to loosen and remove the FRONT oxy sensors on an Alloytec. I cant seem to get a spanner on it from any angle. I was wondering if anyone knows any tricks to get this done.
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you need a stubby 22mm spanner or whatever the size is,
    you can to the left hand side pretty easily from up top,
    but the drivers side is a bit trickier, itll probably be easier to drop the intermediate pipe down, so from the manifold to the cat back sectio as such, you dont have to remove the whole exhaust,
    the worst part is to disconnect the wiring on the drivers side you have to lower the transmission down...., so you have to loosen the transmission mount to get access to the wiring.....
    but wait, thats on the pre 06 models..... so the wiring unclips from the top of the motor on each side just next to the coils..
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Thanks andyman. Yeh the clips are OK on mine, up the top. Its just loosening those sensors that the problem. Ill give it another crack tomorrow. Fingers crossed.
    vt s s1
    Mar 2009
    Havent actually seen one but make sure to spray some rust off a few minutes before.
    Also if your willing, to make less chance of rounding it (cos then your really screwed) cut a hole in the round end of the spanner just enough so you can put the wires through but get a good grip on the head.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Quote Originally Posted by vt s View Post
    Thanx mate. That could be the go... a slot cut in a 22mm ring spanner. NICE!
  1. VZ alloytec (how do i change spark plugs)
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-02-2012, 04:08 PM
  2. how to change co2 sensor
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2010, 01:43 PM
  3. [VR-VS] Change a Coolant temp sensor (V8)
    By undar8ed1 in forum Holden Commodore How-To's
    Last Post: 22-05-2009, 08:09 PM
  4. how 2 change crank angle sensor ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2008, 06:21 PM
  5. Remove Harmonic Balancer to change Crank Angle Sensor?
    By aklahr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 09:18 PM
